1:18 Airwolf Model
Thanks for the video. I didn't even know about this kit.
As bad as it looks, I still want one.
A few pointers:
-You can clean up resin without using acetone. Avoid acetone. You can use 99% isopropyl alcohol to clean up resin very easily.
-use a UV light to cure the inside parts if you can reach them. You might even rig up a penlight with a single UV LED to get inside if your curing station does not include one.
-Put all the parts that had resin leaking from them in the sun. It should only take a short time to do this. If they are exposed to strong sunlight for several minutes they should cure pretty quickly. Most small resin parts cure in less than 5 minutes, so judge your parts by thickness from there. If they need more curing, wait longer.
Thanks again for documenting your journey.
Thanks for the tips and I’m glad you found the video useful. I did use alcohol, I experimented with the acetone on 1 piece and stuck with the alcohol after that.
