1:1 scale imperial probe droid
Cheers guys. Quick update...finished printing the big parts.
Still all the legs and greeblies to model.
Anyone know the history of this droid. I know the studio scale model was made up of Plastruct pieces, found objects and loadsa kitbash parts. But what about the full size droid. Did they just scratch build and scale up all the details, and how accurate was it compared to the model. Obviously they didn't have 3D printing back then so what was the process?
View attachment 768663 View attachment 768664
Looking good, but is it just me or does the head look too small?
When the eyes are there it should be ok.
Both these are from the Lorne Peterson book, If you don't have it, you should look into...
Not the info you wanted GEEK1138 but good all the same :)
Wow thanks for the info Spacebob...i'll be sure to check out that book. And as you say, once all the eyes and stuff go on it should be about right
That's looking awesome to my eyes :) just fantastic.
How tall will it be all in all?
what program do you use to model in, I've bought a 3d printer but wasn't that impressed by sketch up.
Although I was able to make my first model, I haven't printed it yet.
Got the first wee leg printed with all it's greeblies. Leg 'A' I reckon. The joints are to be articulated so that the discs rotate around the central pivot point and are screwed thru the hub. The claw will also 'grab'. I was thinking of adding servo's to make the legs move but I don't think the screen droid's legs move and also, it would be a real mission getting cabling and servo's into all the joint dampers. I'm just testing out greenhouse gas struts that will expand and contract with changes in temperature
UPDATE...first part finished
Didn't print this part in the end, just the small detail parts...scratch built it from a washing machine door, which latches into the other half on the the top of the head. Gonna use electric car aerials for the antenna
OK another update then...Top disc finished , apart from the gun which I plan to have on a pan and tilt mechanism so it will move to fire with sound FX and red LED's
Also been playing around with the 'sixth leg' to hold the droid up
