Hey MB,
WOW! The dry transfers look awesome but again, it goes back to having the ability to print "white". If I can print a vibrant "white" onto a clear decal, that would essentially solve all the issues. I might have to buy an white ink/toner specific printer
SK ... If I'm not mistaken about the dry transfer decals (or at least the ones I'm thinking about) they aren't printed at all, but cut from vinyl with adhesive backing, so whites wouldn't be an issue. Also, no need for clear paper, as once these decals are transferred, there would only be material where the pinstripes are ... Not where just the black or white negative space is. Think about the big transfer decals people put on their back windshields, where you peel away a strip, leaving only decal where the graphic is. Make sense? Not sure if there is a service that could make these custom and small, or if perhaps you couldn't somehow cut them with the laser cutter?
OH OH OH OH!!! That makes total sense and MIGHT just be the way go! My ONLY concern is getting the decal to be perfectly aligned. But I LIKE IT!
I'm pretty sure that's not what's called dry transfers. Dry transfers are printed in an ink with a pressure sensitive adhesive that is stickier than the transfer paper. You lay it on a surface and rub or burnish the text or artwork down and then peel away the transfer paper leaving the artwork on the surface.
Thanks for clarifying, Lt! I guess these are just called "transfer stickers" or "transfer decals" and there seem to be services that will cut them from vinyl. Seems like you can get them pretty small as well.
You could incorporate a thin-stroked outline of the panel around each respective pinstripe graphic, that way you could print multiple panels on a bigger sheet, cut them out and still have a good guide for placement. Also, it looks like there are services that will print multiple colors in the same graphic.
Maybe a service similar to one of these?
https://www.websticker.com/product/...MIrd3HgYqT3QIViSaGCh3noAcpEAAYAiAAEgKOzPD_BwE
https://www.stickermule.com/product...MI8ceerIiT3QIV11mGCh1V0QsXEAAYASAAEgKxrPD_BwE
Hi Gang,
More pics from Dallas, TX!
I sure do miss the ol girl...
The guys replaced the seat pedestals with the old swing arms we used a long time ago...
Custom seat mount
Ken & Mitch trying out the new seat configuration
Looking front to back
More to Follow! :)
Hey MB,
I'm still struggling with my "NEW" printer and its unwillingness to print something decent! I printed two new armrest decals and both have breaks in the prints showing thin white lines. UGH...
Hi Gang,
The End of the Weekend Update is here! GREAT NEWS! Although the new laser cutter power supply isn't here yet, the laser does in fact work at 75% power. And its cutting through acrylic like butter.
It was HOT! With Summer finally coming to an end... the heat and humidity didn't get the memo! ;)
Finally got the rest of the cockpit entrance door pads finished up and shipped to Dallas!
After a bit more Podge and paint
Adding / painting those dirty details
I worked on the Nav Computer - I laser cut the main panels and trim piece - for ref... the Nav Computer is almost 18 inches long
Trim piece is a bit short...
I measured 30 more times and recut
Perfect!
Lets make some greeblies for this Nav Com!
Sanded and adhered together
More greeblie goodness!
I picked up a pack of 1 inch Googly Eyes
I cut off the back and removed the eye leaving the convex "lens"
Sanded and adhered
Primer
Paint
Weathering
Hello, Dave
Adhered the trim piece
Filler
Sanded and Primer
More details
On to the console... I tried reprinting the decals and this continues to happen... :facepalm
This is a BRAND SPANKING NEW PRINTER!
I removed the old decals from the instrument panels
Why? The panels had cracked and I needed to fix
Sanding and filling
I had some fun with the upper instrument panel back plates
Template / mounting guide
MMMMMM Primer!
Paint
Little bit of weathering
I might add a white and or red pinstripe around the edges of the main panel
Worked on the console nose greeblies
X-ACTO for scale (qtr coming!)
Filler
Nose boxes
Vents
More greeblies
Take these pieces
Stack them all up and prime!
Paint
Light weathering - just dust and paint brush
Laid on top of the decal for ref
Instrument panel greeblie(s)
Test piece
Side by Side
Throttle housing trim pieces
Throttle housing!
When the throttle housing was laid in the place... the pin stripes didn't quite align...
But the angles were almost perfect!
UGH! I have NO IDEA where this extra holes came from! :facepalm
It does look cool!
Decal removed
More instrument panel greeblies!
As you can see... I wasn't happy with the angle of the throttle housing
Button panel
Chewie side
I then laser cut all these little buttons... Sadly, they were a bit too small for the button panel openings
White paint
It looks cool but the buttons were a bit small and they just wanted to bounce around and not fit snug...
The holes will get the black switches
With the throttle housing and trim
I then laser cut a NEW housing and this one fit MUCH better
PERFECT!
I laser cut this filler piece
Sanded the edges and pushed into place
Filler
New housing - no more double hole!
Filler added to the edges
I then added more details to the throttle trim pieces
Need to add a bit more filler
And this...
Is where we are!
I'm headed to Dallas, TX this Thursday for the Forth Worth, TX Galactic Swag Expo this weekend!
https://www.galacticswagexpo.com/
I hope to see many of you there! And not to worry... Lots of pics from the show will be coming!
Stay Tuned!
Wow, the amount of work you're churning Sofa is insane:eek Love it!!!!!!!!!!! And enjoy yourself at the Expo; looking forward to pics:)
Great updates! Really looking forward to seeing the canopy done as well as it being skinned! I took a lot at the promo page for that con you're going to... seems there's going to be both a Rey and a Leia attending. You should set up a photo-shoot. Surely there will also be an R2 unit or ten there as well. By the way, I know you started an R2 a long time ago, is that in your pipeline for working on any time soon?
Can't wait to finally see this! I'll be there with my R2 (and maybe one of my floating training remotes) and would LOVE to get some photos!
Hey J,
Thanks so much! Luckily, MOST of the files have already been completed for the full scale and it's been a simple matter of scaling down and laser cutting. There were a few files I said "Oh Yeah... I forgot I had those!" Naturally, I have to make few mod's, here and there, to some of the files but the 1/4 scale has been so much fun! Even better, the new power supply and lenses arrived so we'll be up and running when I get back from TX.
Speaking of which, I head out for TX this evening and I am REALLY excited to meet up with Ken and Mitch. Then I get to stand in front of the cockpit with my arms crossed, eyeing their changes and nodding with approval of their efforts. lol ;)
Hey LtW,
I am excited too! As nervous as I was handing the cockpit off to someone else, I was really dreading working on the canopy. Ken and Mitch jumped right in and started knocking it out! Their efforts have given me a much needed break but I miss her so much!
The Rey that is attending the Con is a personal friend of Ken & Mitch so we'll DEF get some images of Rey. I hope we can get Leia as well. The last show we did, most, if not all, of the cosplayers wanted to get images in the cockpit. We'll DEF get some good photos of the event.
I'm hoping there will be some R2s so they can take advantage of droid socket / terminal I created.
My R2 is sitting in the garage right now. I look at it EVERYDAY with the idea that I will eventually get to it. I'm not sure whether I will do a static or functional R2 - who am I kidding... it'll be fully functional! lol When will I get to it? I have no idea. Once the 1/4 scale cockpit is finished, I'm planning on turning my attention to the 1/6th scale cockpit - file conversion has already started. As you may know, Izzy and I are working very closely together and working on creating a kit of both scales. We're at the 75% point as we're both making mod's and changes to the files for easy assembly.
Hope all that made sense?
Cannot wait to see that canopy done and done...if you catch my drift;)
I do! I really really do! :)
Hey TT,
AWESOME! I'm really looking forward to meeting and greeting! We'll DEF geek out and have fun! Maybe I can trick... I mean persuade you to finish my R2? ;)
See you in a few days!
Just wanted to say I am so excited to get to see this in person this weekend. We will be there with the 501st and Rebel Legion on Saturday. Hopefully we have some fun photo ideas :).
