Hi Gang,
Quick Mid-Week Update!
Making good progress on the corridor pads... These guys are finished and waiting a shot of satin clear
The sides finally got some attention
6 Down... 13 more to go!
I then turned my attention to the next set of pads
This one is going to be fun!
More to Follow So Stay Tuned!
So I didn't have any luck with the cowl files. Had 4 failures to print in the same spot no matter where or how I placed the file on the printer. So plan B. I'm Converted Joshua Maruska Nav Chair file to a STL file and I'm trying to print it. The Cowl was to big to print as one file so I sliced into two files. The 1st half (bottom half) took 65 Hrs to print.
Joshua Marusuka’s file by Izzy Mel, on Flickr
It came out really good. Now the dreaded top part. Get this 123 hrs to print. Yes 5 days to print. hopefully with no issues.
Part two of Maruskas file by Izzy Mel, on Flickr
Hi Gang,
Progress on the pads continues...
Added a few more highlights to the rips and tears
I was thinking about adding a thin layer of coffee and coffee grounds to simulate dirt and grime... What do you all think?
Door pads
Not sure if you can tell, but I've been beating the cr@p out of the one pad that Han hits in ESB - left pad. You can see the beginning of the wear and tear. I will also add a bit more dark wash to that particular area
Just a few more door pads to paint (not including the cockpit entrance pads). I should have some black paint on a few, if not most, of these pads later today!
More to follow! :)
Pads look great!! Kathleen K. would be proud.
Thanks, T! I've always wondered if the folks from LFL, Disney, Fox, etc poke around and see what the fans are doing? :)
https://farm1.staticflickr.com/958/39898174140_245beb5509_c.jpgJoshua Marusuka’s file by Izzy Mel, on Flickr
https://farm1.staticflickr.com/904/39898174150_21e2267123_c.jpgJoshua Marusuka’s file by Izzy Mel, on Flickr
https://farm1.staticflickr.com/953/40987696594_5f14fe85f3_c.jpgJoshua Marusuka’s file by Izzy Mel, on Flickr
https://farm1.staticflickr.com/970/41665395862_51d965feaf_c.jpgJoshua Marusuka’s file by Izzy Mel, on Flickr
https://farm1.staticflickr.com/958/39898282690_415e5e27f8_c.jpgPart two of Maruskas file by Izzy Mel, on Flickr
OH WOW! Those prints are fantastic! And they have the rivets! Fingers crossed no spaghetti!!!
Sofa the pads look totally amazing, as always your work is outstanding, the 3D prints are looking great, with your skill and attention to detail could you not scratch build them quicker yourself in less time ?
Hey I remember a while ago you said you might put a pressure sensor there, to tun the lights on. Are you going to do that after all?
Hey B,
Thank you very much! I appreciate the vote of confidence! :)
Izzy has done an amazing job with all these different 3D models. A HUGE Mega Kudos to him for his continued efforts. I considered making the head piece (cowl) from scratch but 3D printing is much more precise than "flat packing" all the MDF and acrylic together. For me, it made more sense to go that direction. I'm hoping we'll be able to make a mold of the cowl and then be able to knock them out whenever we need one.
Hey OC,
That's the still the plan! We have to get the basics done first before a big event coming up in May but it will DEF be addressed. :)
"I was thinking about adding a thin layer of coffee and coffee grounds to simulate dirt and grime... What do you all think?"
Yes! And the lingering aroma should help block out Chewie's scent...unless he smells like roses and puppies...in that case, not needed.
LMAO!!! Oh yeah... I never really thought about the smell.
Fan: Wow... what a cool project! Can I see it again?
Me: Sure. (To myself) That's funny. I dont recall someone wanting to see it a second time"
With the various connections between Star Wars and 2001, has anyone suggested the Falcon padding being inspired by some of the 2001 sets?
Great update Sofa (and kudos for IzzyMel and its wonderful work)...those pads really look the part now! Wear and tear, that's the name of the game...now, about that coffee grind.
It's the MF!! Not Starbucks :D But, if you really want to get some dark color in there, you could always use tea.
Hi Gang!
You know what time it is? ;)
Continued work on the pads!
Added a few more highlights / dark wash
I love how this combo turned out!
Added a bit more detail! I love how this pad tuned out. Unfortunately...
More pads getting prepped for paint
These two pads were hiding behind one of the Nav Chairs! :facepalm
Color!
Whew...
I love the look of this pad - all the little cracks and divots make it pop. I might repaint it. For some reason the color wash is not consistent - but then again it does add character!
Lots and lots of detail work. I found using sandpaper is a really good way to bring out natural highlights.
Two pads temp in place
I then worked on the cockpit entrance side pads. We CNC'd these pads a while back. It was nice to finally get to them
Podge and shop towels
As I mentioned, I love how this pad turned out. Unfortunately, the pad doesn't fit!
In all my excitement, I measured wrong and now there is a little bit of overhang! This is Chewie's side. UGH
Han's side looking in!
Marked the line and took the pad over to the band saw. I really didn't want to cut this part of the pad but it was the only way to be sure I got an accurate angle
Reduced the interior sides with the table saw
Routed and sanded the edges
Recovered with Podge and Towels
The center piece had to be cut as well
Perfect!
I then repainted
Continued with the detail work
The cockpit entrance side pads still had to be put together
I had to remove a certain amount of material so the pads can rest flush against the panel(s)
These pads are not as deep as the cockpit side but I still had to notch two edges
Mark the sides to cut
Rip across the table saw
Hand cut the rest - foam is really tough to cut through! ;)
Add some filler pieces to extend the length (the door frame angles changed shape a long way back)
Fill the gaps with Podge
Let the Podge dry and then eventually cover (this week)
Jake stopped by to continue his wiring adventures
Illumination!
LED strip
Neat!
Not to get into too much detail as to "why" (more later) but we married up the console and seats for the VERY first time in a LONG while! Enjoy
And this is where we are!
A HUGE Thank You to Jake for his continued efforts!
LOTS MORE to Follow! Stay Tuned! ;)
Superb
Ahhhh cockpit porn
you make an old man happy
well done also to Jake on his illumination work ( everybody should have a Jake )
Wow..what an amazing project!:):thumbsup
Hey K,
Thanks so much! We're getting there!
Hey Lt W,
i thought the same thing. I know there were a LOT of influences from 2001 to SW. I can't remember who said it or when but I believe there the inspiration does in fact exist.
Thanks, J!
LOL! True. Han is no Barista! I was only considering using coffee because of the grounds and the cool texture it would leave. I could always use scale model pigments or just leave well enough alone. ;)
Mega Kudos for Iz's continued work!
Hubba hubba! That's just dang pretty!
Thank you, SB! I must admit, I did stand back and soak it in. It was really cool seeing the console back in place - especially with the seats!
Do I have 3 finals on Wednesday? Yep
Did I just spend the past 3 and a half hours catching up with this thread to avoid studying? You bet your asteroid.
Great work.
Hey M,
LOL! I appreciate the sacrifice! Now get back to those books! ;)
Superb
Ahhhh cockpit porn
Hey B,
Thanks so much! I agree! Everybody needs a Jake. :)
Hi Gang!
BIG NEWS!!!! We are VERY excited to FINALLY let you know that we will be attending this years "Escape Velocity" Sci Fi Convention this May 25-27 at the Marriott Gaylord Hotel in National Harbor, Maryland! We will be bringing the cockpit, quad laser, and various cockpit and SW related props and items! Also, I am very happy to announce that a few "special and important" guests associated with the build will be joining me to help celebrate our 6th year on the project and get the chance meet and greet with all of you!
More Info below!
https://escapevelocity.events/2018/...con-ghostbusters-return-plus-a-special-offer/
Home Page:
We hope to see all of you!
Even Better... More announcements to come! As always, stay tuned for more!
