Pretty sure the pads were made out of fiberglass...maybe gluing a layer of blue insulation foam on top and shape it with a hot cutting wire, sand and coat it with a water based paint?
Apart from that, great work as always Sofa. :cool
Hey J,
Thanks. I have to be honest... I'm really getting frustrated. These 1 step forward 10 steps back weekends really take a lot out of me. Its been really difficult trying to climb back to the original starting point with the "hopes" of any forward progress.
That's my opinion as well. I had the pleasure of chatting with a guy who worked on the TFA sets and he told me all the pads were fiberglass. That leads me to believe the originals were as well. I think that the path forward.
YYEEESS!!! that's so exciting. What a long time in the making for this.
Hey SS,
Agreed! :)
here's a new picture just released by Disney for star wars land
mobile.twitter.com/DisneyParks/status/941004865827942400/photo/1?ref_src=twsrc%5Etfw&ref_url=https%3A%2F%2Fd-17361517374131841470.ampproject.net%2F1512677960104%2Fframe.html
shows alot of the pads
loosebruce
WOW!!!! VERY COOL!
loosebruce
Well that's just great! Now Sofa has to scrap the corridor and start over! ;)
Hey L,
As I explained in a earlier post, covering the pads in a leather-like upholstery material wont work and the plasti-dip wont have the same texture. I think the fiberglass approach is the way to go. I just have to get ONE good solid pad to start with. Disney (any movie studio) has the ability to assemble a team of professionals who know everything from 3D printing to welding to electrical to fiberglass. We're just a handful of knuckleheads trying to figure it out as we go!
The good news is all that we have learned can and will be applied to the next cockpit! No more surprises and guessing our way through the build. :)
Ok......thinking......Once you get your first 'perfect' pad, use it as a buck to vaccuform the rest! You could knock out the others in a couple hours max. Just throwing out simple options.
If you look closely at the pads you can see they were cut kida roughly around the edges. So how to attach? One piece of PVC and two end caps! One end cap gets flipped upside down and screwed into the wall, the other end cap gets screwed base down onto the underside of the pad shell. The you get a measurement on how long to cut the PVC, but make it about .25 short (so you dont bottom out) and glue the three pieces together with PVC cement.
Like this:
Fiberglass is fine but it will take you days and $$$ to make all the pads.
sofa. have you thought about using paper mashee (hope you call it same over there as here) for the pads, I've used it to create so many things including Boba Fett's helmet works easily yes takes time but dries rock solid easily painted can create curves etc also is very cheap.
for those not sure what I'm on about very simply torn up strips of newspaper dunked in a mixture of flour and water then simply stick it to whatever keep building up layers etc until happy, can add more if want after first lot dried.
loosebruce
Hi Gang,
Its that time again! Not much of a weekend update as we all know what weekend this was! :) WOW! The Last Jedi was so much fun! I'm so happy.
Anywho... I tried to salvage the corridor padding
It just wasn't going to happen
Fortunately for me... I've never claimed to know what the heck I'm doing. This has all been trial and error - more error than... ;)
Tried fixing the edges
If you blur your eyes and stand 10 feet away from the monitor... it looks pretty good
UGH
Nope... we're done! It sucks to simply throw all those pads away
Time for a new option! We decided to do a combo 3D print and laser cut pad
New MDF / laser cut frame - everything will be adhered together, sanded smooth and a silicone mold will be made
I then cut horizontal beams down on the capstone panel
Stubby little guy
It fits!
The trim piece is too high so I'll have to do a little mod'ing on the panel - but she's good to go!
Late yesterday Daniel and I worked on the coils
This is el wire being fed through the braided hose
Cut a hole for the wire(s) to feed
Backside
Laying out the wiring
Converter mounted
Wired up!
The LED strip above will be dimmed just a bit so the red el wire really pops!
Coils in place
Daniel then wired up the new silver boxes with the back lit circuit boards
The boards were a natural red color
And this is where we are!
Fun weekend! Can't believe how quickly the movie got here! :)
More to follow!
Those coils look sweeet! I'm not sure you need the upper LED's though. Seems to drown out the EL light. The other little PC boards look cool too.
I love your capstone coffee table. Looking at it installed, I don't think the trim piece needs to come down as much as the door frame seam needs a trim all the way around. If the door were framed, even with just another black piece, the distance between the door and the capstone trim would be lessened.
Gonna try not to make this a spoiler but seeing as how this thread contains a large majority of people that REALLY know the Falcon, I'll ask... Does the TLJ Falcon cockpit appear to be "dummied down" to anyone else? In the scene where Luke is alone in the cockpit reminiscing, they pan around and after a year or more following this thread, all I could think was "Wait, where's the rest of it???".
Sent from my LGLS775 using Tapatalk
LOL! Yup... it was meant to be...
Like this:
http://i.imgur.com/LJKnsRPl.jpg
Hey L,
We're going to try another approach. We're making a new master pad. We create a silicone mold and then pour expandable high density foam (not the spray stuff I've been using) into the mold and then trim the excess. The best part is the pads will be actual foam and simply slip into position. We'll probably use some Velcro to keep them moving around.
loosebruce
Hey LB,
The Paper Mache approach is a great idea. The idea of having actual foam pads, as I explained above, is really exciting and the direction we're going to take. But who knows what will happen! ;)
Thank you, my friend! The white LEDs really do drown out the red el wire. Much more than I expected. We're going to add a dimmer to those particular LED strips to help make the red/coils pop. We're also going to add a blinking effect to one of the coils to give the appearance that its starting to fail.
The door frame needs to be mod'd in order to accept the door padding. With everything around the door frame being black its very deceiving to the eye. I've already redesigned the capstone trim piece by dropping the lower line about .5". It should help balance everything out.
Love the look of the EL wire, great weekend update.
Thank you, my friend! We're going to have a lot of fun with the cockpit entrance. We don't want to get too crazy with the LEDs but we want enough illumination to make it pop :)
Hey ST,
You are not the only one to think that. The cockpit from TLJ appears to have carried over from TFA. The reason, IMO, the cockpit looks so bare is that it appears a majority of the greeblies have been 3D printed and lack that real world look and feel we're so used to seeing from the OT. 3D printing is fun and is certainly an amazing technology but it takes away from what real world objects are. The natural grunge and used look the OT greeblies had a next to impossible to replicate.
However, the MF is 30 years older in TFA so its very safe to say that, if this was a real ship, over the years many of the parts have been replaced with newer and more efficient parts and components. Restoring an automobile requires us to make certain sacrifices if parts are no longer available. I can look past the 3D printed parts. I just wish they had done a bit more prep and weathering to help hide the 3D print textures.
Hope that made sense? :)
Wow, the glowing circuit boards look really nice
Thanks, OC!!! I love the natural red of the circuit board. :)
Great update Sofa...yes, those coils look great (with the lighting and everything). As for those corridor pads, well more trials in perspective; not an easy solution comes to mind.
Off-topic... So we finally got to see one of the Falcon's escape pods in TLJ. Did my eyes deceive me, or did the pod come out of an area that would directly interfere with where one of the back landing gears would be housed?
Nice weekend update for sure.
Thanks, L! Let's hope for more forward progress. All these "Steps Backward" are killing me! ;)
Thanks, J! The coils are finally coming to life. We have a few more surprises for coils so stay tuned! The pads... we never really know what we're getting into until we actually do it. We'll get there.
Hey T,
Finally! Your eyes did not deceive you. I've been chatting with Starkiller and he said, and I quote, "... the pods eject from the rear facets of the landing gear box... the other three facets of the landing gear structure are ports for the other crew (if we're assuming the ship is meant to have a crew of 4 from the cockpit)..."
I'm sure he's already modeling the pod and their locations on his 3D models! :)
Hey T,
I looked at the underside of a model and it looked like the gear would be too close, but if anyone can figure it out, Starkiller will.
Hi Gang,
A Merry Christmas to All! I hope everybody is having a wonderful holiday season and you have been able to share time with family, friends and loved ones! Can you believe 2017 is coming to a close?
Time for the end of the weekend update! This is the last post of 2017! Let's start with all the 3D printing. The nav chair head piece and greeblies are getting close!
Backside
Cant wait to see this guy all finished up and smooth!
Still have to print the top part of the head piece - this is proving VERY difficult because of the shape
The nav chair side greeblies
Printing another part
Finished!
All 3 of these pieces temp taped together
Tough to see
As much as I like 3D printing... there is SO MUCH filling and sanding to so with these home 3D printers. It really takes an effort to get them smooth. I'm looking at getting a higher end 3D printer
1st round of sanding
Primer! Now we find and see all the errors
Yuck!
Had to laser cut this donut
To replace this birds nest of a 3D print
The donut will fit / cover this area
UGH... printer clogged up
Since the pads were a complete bust we decided to laser cut and 3D print a new pad. We'll then take molds from this master buck
Oh joy... more sanding! ;)
2nd round of sanding and filling
The capstone got a new trim piece!
I pulled the bottom down a bit so I added these simple details to fill in the empty space
Primer - this is as far as I got with this piece
Let's move to the maintenance console... I finally boxed in these panels that appeared to be floating - I hated that look!
Laser cut the first of 3 pieces
Sanded the edges flat
Filler
Front panel
Filler
Lots of filler
First round sanded smooth
Now the panels have nice flush look to them
Love it!
Paint
YUCK! Need to fix that area
Looks like an actual console now
Makes all the difference in the world
Upper panel gets the same treatment - and a new design!
New panel being designed - this was tough! I had to work with the existing opening
Interior sides
Perfect fit - didn't have much room to play!
Making the interior edges smooth
Primer
The upper panel is getting a complete make-over! Enjoy!
Sandwiching all the pieces together
What the heck is this?
Edges being adhered to the new trim plate
Front side
Perfect fit!
This is the new face plate
Mounts to the back of the edge piece
Lets put everything together (the MDF piece went through a few modifications to make it all work)
Main panel
It still fits!
Black!
Daniel had the idea to light the clear acrylic from the sides. It was a tight fit so we etched 2 small circles into the back side of the acrylic
Laser cut a new housing with 2 sister holes for white LEDs to mount
Added reflective tape to the top beauty trim piece
LEDs in place! Note how just the edges are illuminated!
Face plate with pinstripes and new illuminated greeblie
Note the holes behind the clear acrylic
Temp in place
I then painted the new greeblie housing Satin Granite
The back of the panel showing the wiring diagram
I had to laser cut a few stand offs
LED
Almost finished up!
We finally got the tablet working
Note the red LEDs behind the new clear acrylic greeblie - these will have a flash pattern
And finally... I laser cut this piece
HMMMMM
Let commit... drilled the corner holes
A new access port! And a slightly new design from the one above
Do I use this greeblie?
Or this greeblie?
Designed a housing that would mount on the interior side of the new opening
I wanted to see what this guy would look like
WHOA! Thats very blue!
Added some pinstripes
Painted the exterior plate
Silver
Painted the interior edges
HMMMMM
Wasn't working for me
Back to this guy!
I like it!
It's missing something...
It needs a friend
It needs something else - designed and laser cut a new housing
The red acrylic will be back lit but I didn't like the circle at all
YES! Much better
Primed the face plate
Note how the silver greeblie sits a bit more recessed into the panel
Redesigned these new mounting plates
New main mounting plate - note all the holes for some LEDs!
From the back
I've got a few minutes... lets test this thing!
Front side showing the LEDs
Its beginning to look a lot like Christmas... OH wait... that was yesterday! ;)
LOVE IT!
And that's where we are! Not sure why but 5-10 pics are gone... oh well...
Merry Christmas and Happy Holidays to All! Be safe and enjoy the New Year! Let's make 2018 awesome! Love you guys & gals!
More to Follow!
