Will definitely have to get this kit! A dream for certain!
My only slight beef with the shots above is that it seems the garbage chute on the lower stem of the conning tower on the back is missing. Perhaps they are still tooling that.
Other than that - this is a must have.
How could Zvezda so BADLY screw this up??? They completely botched the star destroyer's landing gear! They just "invented" two "X" shaped structures on the bottom hull that make no sense at all! Look at the proper landing gear on the Revell kit and compare. Of course we know the landing gear on the Revell are correct and canon because they boast that they used ILM's original files -- so you know they got the details RIGHT!
Although, even if it is closed, the area is nicely defined so easy to open up, and I don't think there's much detail aside from a little box that you'd have to scratch back there.
I've seen some people on other boards claiming the bridge module is oversized in proportions. Any star destroyer experts care to comment on that? I don't know the studio models well enough to say.
Interestingly, I believe I found the same oversize-percentage for the Revell kit´s bridge some weeks ago.
Let´s bring in some mathematics... Someone will chime in and say the lens distortion is different and so on, but that´s the best I can do.
Eh, I'm good with the bridge, considering the next closest alternative to something this size and detailed would set you back about $500, I can live with 9.6 percent at $88!
