Thats just looking like the original solid hull NiceN kit to me, a very generic Red/Gold crossbreed.....or am i way off? Means nothing as it could purely be a mock up placeholder for the announcement? Shame if it turns out that way, as a full on designated Gold replica would have been super!
lee
Looking at Jasons pics, i still think Jamie's pattern has a closer sidewall curve and profile, but, thats only from that one pic, so, hard to say, scribe lines are deeper Steve it seems, thanks for the share J!
Steve, been meaning you shout you, not sure, what your Y is like in the armature cockpit dept in your climate, but the heatwave were having here made my armature warp just a tad with the cockpit module resting on it, only by maybe half an inch, but, enough to make me worry about it.
Ive manipulated it back, but ill be posting a fix using ABS tubing in my thread real soon, id rather fix it properly now that have it happen with the cockpit bonded, that would cause a few unhappy tears. Not a big worry at all though, its a superb kit, need to pull my finger out now lol, anyhow, back to the eFX
lee
Eh up there, Lee! Yeah, the hot climes y neck horror rears its head again... After last summer here in Athens I have a summer regime for the kit: take the head off at the start of June and put it on again come October. That's my temporary fix. But I've been looking into a proper solution - some bracing under the resin half-cylinder. Some kind of long brass block that would be glued/epoxied to, and be absolutely flush with, the aluminium. Figured that the head would not be able to sink the brass if the rear wall of that brass is flush with the aluminium wall. But it's only going to work if the fit is tight as a glove. Any gap between the brass and aluminium and that head gonna sink, man... Apart from that I have no ideas. So, looking forward to seeing your fix...
Steve me old mucka lol, my fix is in my thread, i used the 19mm ABS tube, which is slightly smaller in diameter than the alloy bar but, you have to have a flat area there to clear the lower cockpit plate, so i cut away a slot in the underside of the tube, making it slip tightly over the alloy, and giving me the flat area to nestle inside, worked like a charm mate, so its an idea for you and others, id not trust it to the resin protrusion alone at all TBH.
bests.......lee
Yeah i agree Jamie, a mock up stand in as maybe some kind of placeholder of what is to come, and John has the Gold Leader shizzle down, so it would be awesome to see that bird happen.
lee
John and I spoke again tonight. The Y in question was indeed a placeholder. The final Y will be correct.
Now back to work...
By any chance was any ETA/timeline provided?
TY
The Y does look very nice, though I am very interested in the SD though I am a little scared to find out how much it will cost, If the one shown is how far along they are with it guess it won't be out for a while, least I get some saving time
