razorsharp192
Re: Another BTTF Pepsi Perfect Build Thread.
a hairdryer will sort out any wrinkles easily
You are going to run into a slight wrinkle with printed labels for the Pepsi Perfect - literally.
The shape of the bottle and the location of the decal will cause the decal to compress at the bottom. On a printed label this will cause the vinyl to wrinkle up. When you first apply it, you can flatten it all out and it looks fine, but in a short while it will start to bubble/peel again where it should be compressed.
For the screen used bottles, they use cut vinyl and applied the three colors seperately. The silver backing was applied first and a "pie slice" was taken out of the bottom of the silver part so it would fit correctly without the wrinkly. The red and blue were then applied over the silver.
You can see the cut in the silver backing on my previously posted rubbing. Here is a pic of the production logo as well - look near the bottom.
Hope this helps.
Gary
