roy
Member
Re: Robo3687's IRON MAN Mark 4/6 Pepakura FOAM Templates -Easy to Build "Green" Versi
i used 10mm thk. EVA foam for the torso for stability and for a more defined "step up/step down" especially at the back part. i'm thinking of using 10mm also for the boots and COD piece but for the rest, i'll definitely use the 5mm thk. aside from it being "cutter friendly", it's less tricky...
Thoughts Stealth/Roy/xtracrispy?
