cavx
They sound awesome I hope you make them
Sounds good.
Still making further mods to the patterns and playing with this mesh - which I really like BTW, so yeah this stuff in black would rock!
You are incredibly talented. I have no doubt these will look amazing.
And FYI to anyone who does want to buy them - there positioned for 3mm LEDs in rows of four and each under row starts on the 3rd LED from the above row(just like rd mags)
Durable and have a slight frost to them naturally and the shape is a great resemblance to the real thing.
The only way I can think to get two layers of foam perfectly aligned would be to make one foam shell and them laminated the second to that using the first as a template as you trim it.I'm trying to make them differently but keep the same look, if I wanted a accurate pair for a start they would not be black lol
I tried a two layer but I had no luck, so hard forming both pieces and getting them to line up perfect.
If I could have two layers of foam I would have trust me
I hope that was all clear as I have a bad habit of blurping out from my head.
Some pics of my heel cups so far..
1) Plastic bonding primer
2) Schwartz grey coat(light spray enough to cover surface)
3) Applied some masking tape around lettering (I will do the detail texture afterwards when I can control it better without tape in the way)
4) Stone finish spray paint, 1 hour set time for first coat as pictured)
5) Waited for 1st to dry and then applied a thin 2nd coat(as pictured)
6) Tomorrow just to apply a Schwartz grey(T.B.A)
7) Remove mask tape and add finer detailed texture with puffy paint around letters then Schwartz grey to cover(T.B.A)
8)Apply 2nd session of masking tape to cover letters again.
9)Paint splatter, new technique will update with progress but will consist of a pin, water paint and thin plastic card (T.B.A)
10) remove masking tape(T.B.A)
11) Paint lettering(T.B.A)
I hope these steps and info is helpful
Note I will amend this post tomorrow with more pics and step updates.
All made sense to me, thanks. I am sure I can think of many questions to ask your opinion on.
These Heel Cups will rock.
That paint I used for my splatter was actually water based. The cool part being - easy to clean off any areas not meant to have paint on them. Once dry, you need to more than water to get it off, but it doesn't seem to scrape off easy either.
The inner sole you are on about the white nike insert sole that you can take in and out?
Ye I have two pairs of silver and one pair of blue/black coloured v1's.
I was tempted to use the blue/black shoe as it has a red sole but I am doubtful on how much light it will let through.
Do you think I could take the clear soles off the v2's and put it on the v1's?
