Hi Gang,
Happy Monday! Another weekend come and gone. Believe it or not I didn't take as many pics as I would have liked. We have been busy busy all weekend but there were more behind the scene goings on - planning, dimension taking, designing, CNC cutting etc... BUT we did manage to get a few things done and we jumped ALL over the place... Enjoy!
We found out the issue with the new nose frame and got that taken care of. Jessie and I dismantled the nose cone
We'll jump back to that in a sec...
We also started work on the seats
HUGE disappointment... these are NOT the same style seats used in the original MF set. These are just tad bit too small. It's the same shape but it would appear to have been scaled down by 5-10%
BUT... we're going to recover and have fun with what we have. Daniel has taken the material off in prep for new screen accurate covers
I spent Saturday morning with the laser cutter. I designed this new greeblie
Jessie applying filler
First of many passes with the sander, primer filler, etc
Slowly coming together
Primer
Paint
Silver!
Def needs some weathering!
Fab'd a new one of these instrument panel greeblies - HUGE thanks to Jessie for adhering and sanding this little guy
I laser cut this interesting light bar that sits atop of the console
And primer
I laser cut donuts for the yokes
Laser cut these smaller square tiles
I also spent a LOT of time trying to figure out how to make these canopy box handles move
This idea worked but it wasn't beefy enough
Cover plate
Spacers
I didn't get any detailed images of how the mech actually works - I'll explain on a later post
I'm not very happy with the overall design
We'll figure it out
I pulled this lever assembly from the old console - I will be repainting and adding to the new console
A LOT of attention was also given to the front window - cut these spacers
They will fit into these openings to keep the "petals" from flexing and give support
Jessie and I then added expandable foam to the center ring!
This fills ALL the gaps and def keeps the weight down
We then added filler to the open edges around each "petal"
I then trimmed the foam
Jessie and I attached the inner "petals" to the window - some material had to be removed so edges could meet
Interior "petals" in place - needs lot of attention!
With the "petals" in place I added more foam
This is a FUN process! I'm really enjoying working on the window
Waiting for the foam to dry
Interior side
Jessie and Samantha stopped by on Sunday to help out again! Samantha trimmed out all the foam while I relaxed
Still more foam to add
After sanding the wood filler I added Bondo to all the exterior seams
Sanding the Bondo took me back to my fiber glassing days! Sanded and added first coat of primer on exterior
Once all the edges are cleaned, the "petals" secured and everything is all in place I will then cut and add styrene to cover the openings!
And Finally... Another HUGE Thank You to OperaScot and Daniel for getting all these measurements down and Daniel spending most of Sunday at the CNC cutting the ribs and Volvo panels for the boat frame! I think there is a time lapse vid coming!
Main arch
Volvo Panels
The big question... does it fit?
YES!
This is only a dry fit but from what I can see and once everything is aligned... SUCCESS
As always, Thank You Scot, Daniel, Jessie and Samantha for all your help!
More to Follow!
