Nice work, Greg.
I'm out of the theatre today (where the toy is), so I'm hanging with the kids. But, before the day off, I was able to get a few more things taken care of on the quad.
I finally picked up some long enough bolts to attach the ballast portion to the body.
Now it was time to start putting the printed side panels on the plexi backing for the shield walls. I knew going in that I would have some adjustment to do as I added the pieces, and I needed to start with the yoke surrounds.
You know, crazy glue dries almost instantly. When you don't have a craft store anywhere near the job site, or time to get to a location with decent adhesive, you make do, I guess. Either way, securing the ABS printed parts to the plexi was, um, entertaining.
One of the pieces (per side) includes a pair of vents, and I was going to use some window screening material for it. Again, the time constarints of two show days for 8 days in a row came into play, along with the fact that I didn't want to buy a 20' roll of screen for 12 square inches of use. Then the idea of a stove filter popped up.
I had printed all the parts to have chamfered edges, so that once the pieces were in place, they would be friction welded together.
Some of the welds look goo. Others, well, let's just say I'm going to have to weather a couple of spots pretty well.
This is for the port wall. I got all the pieces that are not access hatches for the valves glued on and welded to each other and the plexi. The other two parts need a little work yet.
Then it was time to attach the surface to the frame. I love those 10-24 bolts.
The yoke arm is hanging in place in this picture, with the side wall firmly attached in its proper place. In addition, the weird angles piece is atached on the back end of the ballast section. This was how it sat over Christmas.
Hope all of you are having a great holiday season.
Scot
