Captain Canada: The First Peacekeeper
lots of amazing work in this forum since the beginning but this one is absolutely fantastic,the colors are perfect everything you did is awesome.it's very different and refreshing.thanks man you made my day.
Francois
What would Cap be without a helmet?
I decided that the best choice would be to get a Cattoys Rookie version helmet and attempt to mod it to get as close to my prototype style as I can.
Standard practice is to cut off the A, replace the chin-cup, and paint slightly differently. I'm going to be painting a lot differently, and I need to find a solution for the maple leafs on the sides. I don't think I'll replace the chin cup as I don't really mind how it looks and this is custom anyway.
I went with Angelus leather paints, as is common with other Caps when modding. However I found that the "Autumn" Red and "Burgundy" were quite orange and purple respectively, so I'd warn anyone getting from them that their sample colour images on the site don't really match the real paint that well. I did a test mixing the two and came to a result I was happy with (Autumn on the left, mixture on the right, fabric for colour reference)
Used a razor blade to remove the A, and gave the whole thing a sand with 320 grit and a wash. Rubbed down with acetone and it was on to painting!
Yep, I will be doing a painting time lapse! Here it is after three coats. I left the wings bare for now, as I wasn't able to sand all of the silver away, and painting over it would contaminate my paint, so I'll do them last in red and then go over them in the pewter colour I have.
So I'm very encouraged by the results! This is a great base helmet if you wanted to do something similar but a little custom and the painting of it has not been difficult at all. Thanks again to everyone checking it out!
I love this so much.
Regarding the maple leaves, would a tourist souvenir shop have ... plastic magnets in the shape of maple leaves? Or maybe the dollar store? Or maybe the craft store would have wooden or plastic or metal leaves?
Im looking into 3D printing something for it. I can use the same image as I did for the chest star and the shield and extrude a 3D shape so that all the logos on the suit match one another. The printer from a friend that I'll be using apparently prints flexible material so its perfect!
Progress!
Calling this done until I get the C and the leafs on it. Really happy how it turned out, and I love the wings in particular!
Cattoys Mod vs. Craft foam prototype
Thanks for checking it out, I gotta be done by July 1st!
Meant to do this, shoulder post!
I really wasn't sure how to approach these at first, but I knew I'd have to double up foam layers to get it done.
Luckily another Cap shared a paper template so I printed and cut out the shapes on card stock and played with scale to make sure they fit my body.
I then transferred the outline and individual shapes to 4mm foam and glued them together.
After that I had to source a glue that would adhere to both foam and fabric, be flexible, and dry clear. I did a couple of tests to see how the result would look on some scraps.
And then it's time to do the real thing! I put the glue into the edges and layer the fabric on top and used this stick to tamp the edges in. The glue doesn't fully dry for 24 hours so if things go wrong you can adjust.
This technique was actually stupid easy and really effective. For any costume that has kind of armour panels this would be a great approach.
Thanks!
Hey, it's Canada Day!
...Apropos of nothing...
  • CapCan02.pdf
  • CapCan01.pdf
Ha! Cool!
Couple pics from Canada Day at the Vancouver Convention Centre, which was a ton of fun. Sooooooooooo many photos.
lil update:
Released a preview vid of the helmet time lapse. Full vid will be done when all the icons are on and the helmet is finished and will have the full process on there. Until then, enjoy!
Hey everyone!
After a long while of planning and getting the right time, I've done a shoot with my pal Meg Super!
Lovelovelove how these turned out and glad to include my helmet even if its not completely done yet.
Thanks for looking!
