Re: Bullet Casing on RotS Reveal Mask??
Hi m8
As you said it looks as if the centre is a hex, which would indicate a countersunk set screw, which might also account for the 'fz' as they often have a spec stamped into them. I would go for alloy tube with countersunk set screw in the end, you just need to work out the size to get to correct screw.
It doesn't look like a bullet casing because it looks alloy, and going by the size would say a .22 rimfire at most, but then the wall looks too thick, plus they would normally be brass.
