Didact
Greetings everyone! I recently moved and while my wife was packing things away they stumbled upon a 1/1 Darth Vader helmet I got from TRU years ago. It's completely plastic and I completely forgot about it. When I found it, it had bits broken off and the paint has faded along with the gloss so I took it upon myself to buy some putty and fix it up. Now I've been working on it lately and I have a couple of questions I was hoping some of you painting experts can help me with.
Here's a step by step of what I did:
1) Sanded out areas I wanted to apply the putty
2) I applied the putty and worked on it, allowed it to dry and sanded it down with 1500 grit until it was super smooth.
3) I then sanded the entire Dome, stripping the paint first with a lower grit and then I sanded it down until it had a nice smooth feel.
3) Bought Tamiya Fine Surface Primer and I primed it with 2 coats.
4) I left it to dry for 24 hours and about an hour ago I spray painted it with 3 nice coats of Tamiya Black.
Now as it's drying now, it doesn't have a completely smooth surface. It almost has a grainy texture to it. The surface just looks grainy and not gloss smooth.
I bought Tamiya Semi Gloss Clear as a top coat but I was curious if you fellow members can help my make my future spray painting progress better.
Now I have a couple of questions.
1) Should I leave the paint to dry for 24 hours before applying the semi gloss? Can I spray it with coats of the gloss clear right away or is there some sanding I need to do to achieve that super smooth glossy surface? Since I'm using Semi Gloss I'm not looking for a glass effect but I would like my surface to lose the grainy texture it has so that when I handle it, it's smooth when I slide my finger. How do I go about getting that? I bought the following a couple of minutes ago in case they will help me:
3600-12000 Grit Polish Pad
Micro Mesh HSX200 Paint Polishing Soft Touch Pads 5 Grits 3600 to 12000 | eBay
Novus Plastic Polish
Novus Plastic Polish 1 2 3 2oz Bottles 1 Each Scratch Remover Cleaner Kit | eBay
2) Is there any sanding/wet sanding that I should have done in between one of my steps to make the outcome better?
3) Instead of spraying the Semi Gloss, can I use the Novus Kit to make a smooth surface or do I need to spray the semi gloss first and then use the kit to polish it?
As I said before, any suggestion will be thankful as I'll be working on the helmet itself after I'm done with the Dome.
