Hi, I'm working on a project and I'm getting mixed results with a material, would like some advice if possible.
I'm slush casting a helmet with smooth cast 321. While I'm working with it everything seems fine and goes everywhere smoothly but as soon as it begins to get milky little bubbles pop up in it. And not just a few bubbles, but the whole thing turns into an aero bar. I tried thin layers, thick, I get the same results. I'm thinking that as it gels and rolls around slower it picks up air which doesn't have a chance to escape. I'd like to stop slushing it before it gels but then it just gathers at the bottom. I'm trying to build up as many small layers as I can but I'm afraid that all the air is going to make it weak and prone to snapping off. Any suggestions? I tried a layer mixed with ure-fil3, it worked out great but I wanted a layer without it for the final one to get a smooth finish inside.
On a side note, I've used smooth cast 300 before with no problems. I wanted to get a material that doesn't set as fast to avoid lumps, so if anyone can shine a light on what I might be doing wrong it would be greatly appreciated.
