Well, I have yet to see a thread about this, and I guess it can be considered an easy project for most of you guys out there, but I thought I'd start a thread anyhow.
Here's what I've got so far. Took me about three hours to get to the first "semi" coat of primer.
If I had to do it again, I'd do the teeth differently. I kinda screwed mine up. I ended up using the front side of a dremel cut-off wheel on the inside of the helmet to slowly remove the excess material. In doing so, I messed up the thickness of the teeth. I probably shoulda just used a drill to remove most of it then a file for cleanup. Live and learn I guess.
Anyway, I'm taking a break for awhile. Need to go to the store and get some velcro, more primer, and something to use for the gunmetal. I don't really have hobby stores around here so I'm not sure what I'm gonna use for that.
