Sewing Machines - Presser Feet
Let's see if I can answer tic toc's question.
Your sewing machine comes with a handful of feet. Typically one is for all purpose sewing and the others are for specialized functions. You can also buy others that are even more specialized.
All Purpose or Zigzag Foot
This foot is typically installed on the machine when you purchase it. If you notice, the hole the needle goes through is wide, wide enough to allow the needle not to hit the foot on the widest zigzag stitch setting.
In this picture, the foot on the left and in the center are zigzag feet from two different machine manufacturers.
Zipper Foot
In the above picture, the zipper foot is on the right.
This foot is typically narrower than the all purpose foot. It is designed to run next to the teeth on a zipper. The foot can be attached to the presser foot holder so that you can stitch on both sides of the zipper.
Your foot may look slightly different in that the foot slides along bar. This is an adjustable zipper foot. This type of foot is also used to sew on piping. (Piping is a type of fabric trim where a piece of fabric is folded around a narrow cord and typically inserted in a seam. The black trim on the back of a Star Trek: WoK jacket is piping.)
Overcasting Foot
This is the foot on the left in the above picture. This foot is used to overcast the raw edge of fabric to prevent the fabric from raveling. You put the raw edge of the fabric against the guide on the bottom of the foot.
Monogramming Foot
This is the foot in the center. This foot is used for machine embroidery, scallop or other decorative stitching, and eyelets
Blind Stitch Foot
The foot on the right is used for blind stitch hemming (like on a pair of dress pants) Plan on making a number of test runs to ensure that the stitch is small on the right side of the fabric yet catches the hem on the wrong side.
Button Foot
The foot on top is used to sew on two or four hole buttons. I've never been successful using this foot. I still sew my buttons on by hand.
Buttonhole Foot
To "automatically" make button holes the correct length. You will need to make a lot of test button holes to ensure the length is correct, the width is correct, and the stitching is even on both sides of the button hole.
Other Specialty Feet You May Want to Investigate
Top Stitching Foot
Typically clear plastic; the foot allows you to see the edges of your garment. (Top stitching is that line of stitching next to a folded edge like on a collar or cuff.)
Walking Foot
Used to sew slippery fabrics or plaids. In typical sewing, the feed dogs move the bottom layer of fabric and the top layer of fabric goes along for the ride. The walking foot adds another set of feed dogs that work in concert with the lower feed dogs so that both layers of fabric are pulled through the machine.
Non-Stick Foot; a.k.a., Teflon Foot
Used to sew vinyl and pleather
NOTE:
When you change feet, use the hand wheel to carefully lower the needle to ensure it does not hit the foot. Otherwise you run the risk of breaking the needle or the foot.
Lynn
