Great work!! What kind of release agent are you using?? And would it be possible to still coat the dread in thinned down urethane rubber despite having some release agent left on the dread.
Thanks in advance
Thanks in advance
Other than the hole that you use to pump air into.. Is there an additional hole at the same end to prevent air being trapped at the tip of the dread
Thanks again in advance
