Seam Problems After Applying Plasti Dip
mascotman
I just finished an original design gladiator helmet in EVA foam (my first try) and thought that I had the seams ready for the Plasti Dip. After applying I'm just not satisfied with the seam lines. I'm looking for recommendations for whatever product(s) that I can use to go back over the seams and fill the gaps so that I can put the final coatings of Plasti Dip on. I used contact cement for the joint lines.
topshape
Member
What are you not satisfied with? Are you trying to hide the seams? Or is there a small gap where the 2 pieces join? If it's for filling gaps I noticed with hot glue if I was real careful I could eliminate the gaps. I also experimented with acrylic/silicone blended caulking for filling spaces. It shrank a little, but I would think after few coats it would level out. Since it's for a helmet I assume it won't be flexing much, so you should be safe. Don't use pure silicone caulking, nothing sticks to silicone except more silicone.
infymys
I found vinyl spackle to be very good in filling in the bigger gaps. Sandable, flexible, paintable and very lightweight. Just make sure it's completely dry before sanding.
mascotman
Familyman, By the time that I seen your post I had already made some corrections on the seams. I'll post a pic if it doesn't come out well and I have to go back and do some more work.
