Hello everyone,
Good to be here officially after lurking for a while. I'm a newbie to prop making and I would like to expand my skill set and create all my favorite nerd junk!
I have some questions about making large resin casts lighter. I recently created a sword about 36" long and cast it solid with Smooth-On's Feather Light resin. I assumed that since the company claims this type of resin floats in water, that I would end up with something fairly lightweight. When I pulled it out of the mold, I found I was terribly mistaken! The sword weighed way too much for my noodly arms and was very unpleasant to carry around a convention.
So I've been researching expandable urethane foam as a filler and I think this may be the solution to my weight problem. My plan is to figure out how I can create a resin shell of my sword and fill it with foam, or find a good self-skinning foam if one exists. Problem is, I can't quite wrap my head around the resin shell part of it. Should I rotocast it and find a way to leave a gap for the foam to be poured into? Do I brush thickened resin into both parts of my mold leaving an escape/pour hole, and then fill it with the foam and clamp the halves shut before it explodes (if I do it this way, how do I address the parting seam if there is one)? Most of the videos I've looked up on YouTube explain how to use expanding foam with open-ended molds, but I'm using a two part mold.
In short, what's the best way to back fill a two-part mold? Or, is there a decent self-skinning foam out there somewhere? Any help would be greatly appreciated!
