Python replacement for flash sentry gun terminal code
ksj
Been working a month or so on this. Verified to work on windows 10.
Python:
import tkinter as tk
from tkinter import *
#import PIL.ImageTk
#import image
#import PIL
#import PIL.Image
import tkinter.ttk as ttk
import datetime as dt
import time
import os
from tkinter import messagebox
from collections import deque
from itertools import islice
from threading import Thread
from playsound import playsound
# global variables will be declared here
GUN = ""
# sets ammo count to initial value of 500
INITIAL_COUNTER_VALUE = 500
# sets initial time at 100%
INITIAL_TIMER_VALUE = 33000
# sets initial gun terminal ID
#sets gun rate
RMMAX = 0
# sets initial temparature
TEMP_INITIAL = 20
# sets text string for ammo/temp/low ammo status button
STATUS = ""
COOLED = 20
# end global variables section
# This is the initial screen that loads and then disappears after 8 seconds
# I used 3 images to make the main deal.  The issue was that pygame allowed for line draws
# tkinter only allows for drawing of boxes.
# should this change I will change from using images.
class SplashFrame(tk.Toplevel):
    def __init__(self, *args, **kwargs):
        super().__init__(*args, **kwargs)
        self.geometry('640x400')
        self.title("Iniitaling")
        self.img = tk.PhotoImage(file='load5.png')
        self.configure(background='black')
        self.overrideredirect(True)
        tk.Grid.rowconfigure(self, 0, weight=1, uniform='a')
        tk.Grid.columnconfigure(self, 0, weight=1, uniform='a')
        tk.Grid.rowconfigure(self, 1, weight=1, uniform='a')
        tk.Grid.rowconfigure(self, 2, weight=1, uniform='a')
        tk.Grid.columnconfigure(self, 1, weight=1, uniform='a')
        tk.Grid.columnconfigure(self, 2, weight=1, uniform='a')
        self.leftimage = PhotoImage(file='loadleft22.png')
        left = ttk.Label(self, style="TLabel", image=self.leftimage)
        left.grid(row=2, column=0, sticky="NSEW")
        self.rightimage = PhotoImage(file='loadright3.png')
        right = ttk.Label(self, style="TLabel", image=self.rightimage)
        right.grid(row=2, column=2, sticky="NSEW")
        btn = tk.Label(self, image=self.img)
        btn.grid(row=0, rowspan=2, column=0, columnspan=3, sticky="NSEW")
        styled = ttk.Style()
        styled.theme_use('clam')
        styled.configure("TLabel", background='black', darkcolor='black', bordercolor='black', relief='none', lightcolor='black', highlightcolor='black', foreground='black', shiftrelief=-5, highlightthickness=0, width=0, anchor="NSEW")
        styled.configure("Horizontal.TProgressbar", foreground = 'black', background = 'yellow', bordercolor='black', darkcolor='black', throughcolor='black', lightcolor='black')
        loadingbar = ttk.Progressbar(self, style="Horizontal.TProgressbar", orient="horizontal", length = 200, mode='indeterminate', maximum=100)
        loadingbar.grid(row=2, column=1, sticky="NEW")
        loadingbar.start([78])
# self.after has a timer in msecs.  Just change this to your desired value.  I have logic on loading bar set for 8 seconds so if you change that
# you will need to adjust the loadingbar.start number.  Remember it is 200 units long and you divide that by the time in msecs to figure out how to divide up the movement
        self.after(1000, self.destroy)
# End of splash screen defined class and related functions
#------------begin select screen------------------------------
# Begin select menu defined class and related functions
# This is the script's core window so more code will be present here than in other sections
# This is the next screen to load after the initial splash screen
class TkApp(tk.Tk):
        self.title("Select Screen")
        self.configure(bg='black')
        self.gun = tk.StringVar()
        self.gun.set(GUN)
        # Specify Grid
        tk.Grid.rowconfigure(self, 1, weight=1, uniform='b')
        tk.Grid.rowconfigure(self, 2, weight=1, uniform='b')
        tk.Grid.rowconfigure(self, 3, weight=1, uniform='b')
        tk.Grid.rowconfigure(self, 4, weight=1, uniform='b')
        tk.Grid.rowconfigure(self, 5, weight=1, uniform='b')
        tk.Grid.rowconfigure(self, 6, weight=1, uniform='b')
        tk.Grid.rowconfigure(self, 7, weight=1, uniform='b')
        tk.Grid.rowconfigure(self, 8, weight=1, uniform='b')
        tk.Grid.rowconfigure(self, 9, weight=1, uniform='b')
        tk.Grid.columnconfigure(self, 0, weight=1, uniform='d')
        tk.Grid.columnconfigure(self, 1, weight=1, uniform='d')
        tk.Grid.columnconfigure(self, 2, weight=1, uniform='d')
        tk.Grid.columnconfigure(self, 3, weight=1, uniform='d')
        tk.Grid.columnconfigure(self, 4, weight=1, uniform='d')
        tk.Grid.columnconfigure(self, 5, weight=1, uniform='d')
        tk.Grid.columnconfigure(self, 6, weight=1, uniform='d')
        tk.Grid.columnconfigure(self, 7, weight=1, uniform='d')
        button_1 = tk.Button(self, justify=tk.CENTER, text="AUTO-REMOTE", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        button_2 = tk.Button(self, justify=tk.CENTER, text="HARD", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        button_3 = tk.Button(self, justify=tk.CENTER, text="SEMIHARD", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        button_4 = tk.Button(self, justify=tk.CENTER, text="SOFT", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        sbutton_1 = tk.Button(self, justify=tk.CENTER, text="BIO", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        sbutton_2 = tk.Button(self, justify=tk.CENTER, text="INERT", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        tsbutton_1 = tk.Button(self, justify=tk.CENTER, text="MULTI SPEC", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        tsbutton_2 = tk.Button(self, justify=tk.CENTER, text="INFRA RED", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        tsbutton_3 = tk.Button(self, justify=tk.CENTER, text="UV", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        wsbutton_1 = tk.Button(self, justify=tk.CENTER, text="SAFE", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        wsbutton_2 = tk.Button(self, justify=tk.CENTER, text="ARMED", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        isbutton_1 = tk.Button(self, justify=tk.CENTER, text="SEARCH", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        isbutton_2 = tk.Button(self, justify=tk.CENTER, text="TEST", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        isbutton_3 = tk.Button(self, justify=tk.CENTER, text="ENGAGED", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        isbutton_4 = tk.Button(self, justify=tk.CENTER, text="INTERROGATE", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        trbutton_1 = tk.Button(self, justify=tk.CENTER, text="AUTO", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        trbutton_2 = tk.Button(self, justify=tk.CENTER, text="SELECTIVE", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        smman = tk.Button(self, justify=tk.CENTER, text="MAN-OVERRIDE", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        smauto = tk.Button(self, justify=tk.CENTER, text="SEMI-AUTO", bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        # displays gun id on top left and right of screen
        gun_1 = tk.Button(self, borderwidth=7,bg='black',fg='yellow',disabledforeground='yellow',state=tk.DISABLED,textvariable=self.gun, highlightcolor = 'yellow')
        gun_2 = tk.Button(self, borderwidth=7,bg='black',fg='yellow',disabledforeground='yellow',state=tk.DISABLED,textvariable=self.gun)
        headernew = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="UA         571-C \n REMOTE SENTRY WEAPON SYSTEM")
        syst = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="SYSTEM \n   MODE")
        weap = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="WEAPON \n   STATUS")
        iff = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="IFF \n   STATUS")
        test = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="TEST \n   ROUTINE")
        target = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="TARGET PROFILE")
        spectral = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="SPECTRAL PROFILE")
        ts = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="TARGET SELECT")
        gun_1.grid(row=0, column=0, ipadx=2, ipady=2, padx=2, pady=2, sticky=W)
        gun_2.grid(row=0, column=7, ipadx=2, ipady=2, padx=2, pady=2, sticky=E)
        headernew.grid(row=0, column=1, columnspan=6, sticky="NSEW")
        button_1.grid(row=2, column=0, columnspan=2, sticky="NSEW")
        button_2.grid(row=9, column=0, columnspan=3, sticky="NSEW")
        button_3.grid(row=8, column=0, columnspan=3, sticky="NSEW")
        button_4.grid(row=7, column=0, columnspan=3, sticky="NSEW")
        sbutton_1.grid(row=7, column=3, columnspan=2, sticky="NSEW")
        sbutton_2.grid(row=8, column=3, columnspan=2, sticky="NSEW")
        tsbutton_1.grid(row=7, column=5, columnspan=3, sticky="NSEW")
        tsbutton_2.grid(row=8, column=5, columnspan=3, sticky="NSEW")
        tsbutton_3.grid(row=9, column=5, columnspan=3, sticky="NSEW")
        wsbutton_1.grid(row=2, column=2, columnspan=2, sticky="NSEW")
        wsbutton_2.grid(row=3, column=2, columnspan=2, sticky="NSEW")
        isbutton_1.grid(row=2, column=4, columnspan=2, sticky="NSEW")
        isbutton_2.grid(row=3, column=4, columnspan=2, sticky="NSEW")
        isbutton_3.grid(row=4, column=4, columnspan=2, sticky="NSEW")
        isbutton_4.grid(row=5, column=4, columnspan=2, sticky="NSEW")
        trbutton_1.grid(row=2, column=6, columnspan=2, sticky="NSEW")
        trbutton_2.grid(row=3, column=6, columnspan=2, sticky="NSEW")
        smman.grid(row=3, column=0, columnspan=2, sticky="NSEW")
        smauto.grid(row=4, column=0, columnspan=2, sticky="NSEW")
        syst.grid(row=1, column=0, columnspan=2, sticky="NSEW")
        weap.grid(row=1, column=2, columnspan=2, sticky="NSEW")
        iff.grid(row=1, column=4, columnspan=2, sticky="NSEW")
        test.grid(row=1, column=6, columnspan=2, sticky="NSEW")
        target.grid(row=6, column=0, columnspan=3, sticky="NSEW")
        spectral.grid(row=6, column=3, columnspan=2, sticky="NSEW")
        ts.grid(row=6, column=5, columnspan=3, sticky="NSEW")
        # this quits by clicking a button labeled q
        quit = tk.Button(self, bg='black', fg='yellow', text='q', command=self.quit)
        quit.grid(row=8,column=0,sticky="SW")
        self.bind('<KeyPress-Down>', self.on_down)
        self.bind("<Up>", self.on_up)
        self.bind("<Left>", self.on_left)
        self.bind("<Right>", self.on_right)
        self.bind("<KeyPress-a>", self.on_keypress_a)
        self.bind("<KeyPress-b>", self.on_keypress_b)
        self.bind("<KeyPress-c>", self.on_keypress_c)
        self.bind("<KeyPress-d>", self.on_keypress_d)
        self.bind("<KeyPress-q>", self.on_keypress_q)
        tk.Button(self, text='SecondFrame', command=self.on_button, bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow').grid(row=9, column=0, sticky="SW")
        self.create_splashframe()
        # These are the bind key definitions
        self.bind("<KeyPress-r>", self.on_keypress_r)
        self.bind("<KeyPress-space>", self.on_keypress_space)
        self.bind("<KeyPress-k>", self.on_keypress_k)
        self.group1 = deque((button_1, smman, smauto))
        self.group2 = deque((wsbutton_1, wsbutton_2))
        self.group3 = deque((isbutton_1, isbutton_2, isbutton_3, isbutton_4))
        self.group4 = deque((trbutton_1, trbutton_2))
        self.group5 = deque((button_4, button_3, button_2))
        self.group6 = deque((sbutton_1, sbutton_2))
        self.group7 = deque((tsbutton_1, tsbutton_2, tsbutton_3))
        self.header_group = deque(((syst, self.group1), (weap, self.group2),(iff, self.group3), (test, self.group4),(target, self.group5), (spectral, self.group6),(ts, self.group7)))
        self.start_with_first_selected(False)
        self.toggle_header_group(self.header_group)
    def toggle_button_group(self, button_group):
        button_group[0].config(foreground='black', background='yellow', relief='sunken')
        for button in islice(button_group, 1, None):
            button.config(foreground='yellow', background='black', relief='raised')
    def toggle_header_group(self, header_group):
        header_group[0][0].config(disabledforeground='black', background='yellow', relief='sunken')
        for button in islice(self.header_group, 1, None):
            button[0].config(disabledforeground='yellow',background='black', relief='raised')
    def start_with_first_selected(self, first_selected=False):
        if first_selected:
           toggle_button_group(self.group1)
           toggle_button_group(self.group2)
           toggle_button_group(self.group3)
           toggle_button_group(self.group4)
           toggle_button_group(self.group5)
           toggle_button_group(self.group6)
           toggle_button_group(self.group7)
        else:
        # set last of each group to selected
           self.group1.rotate(1)
           self.group2.rotate(1)
           self.group3.rotate(1)
           self.group4.rotate(1)
           self.group5.rotate(1)
           self.group6.rotate(1)
           self.group7.rotate(1)
    def on_down(self, evet):
       group = self.header_group[0][1]
       group.rotate(-1)
       self.toggle_button_group(group)
       playsound("click1.mp3")
    def on_up(self, evet):
       group.rotate(1)
    def on_left(self, evet):
       self.header_group.rotate(1)
    def on_right(self, evet):
       self.header_group.rotate(-1)
 # this appears to launch the initial window
    def create_splashframe(self):
        splashframe = SplashFrame(self)
        self.withdraw()
        self.wait_window(splashframe)
        self.deiconify()
# this launches the next screen, the fire select screen
    def on_button(self):
        secondframe = SecondFrame(self)
        self.withdraw()
        self.wait_window(secondframe)
        self.deiconify()
    def kudos(self):
        kudosframe = KudosFrame(self)
        self.withdraw()
        self.wait_window(kudosframe)
        self.deiconify()
    def on_keypress_k(self, evet):
        print("k pressed")
        self.kudos()
    # these work
    def on_keypress_a(self, evet):
        which_gun = self.gun.get()
        which_gun = "A"
        self.gun.set(which_gun)
    def on_keypress_b(self, evet):
        which_gun = "B"
    def on_keypress_c(self, evet):
        which_gun = "C"
    def on_keypress_d(self, evet):
        which_gun = "D"
# this launches you to window three, the fire select window
    def on_keypress_space(self, evet):
        print("space pressed")
        self.on_button()
# this quits and closes the window by hitting a single key
    def on_keypress_q(self, evet):
        self.quit()
# this reloads the game, you have to click it to make it the active window again
    def on_keypress_r(self, evet):
        self.destroy()
        self.__init__()
# this is the third fire screen
class SecondFrame(tk.Toplevel):
        self.title("Fire status screen")
        tk.Button(self, text='Close', command=self.destroy, bg='black', fg='yellow', highlightbackground='yellow', highlightcolor='black',activebackground='yellow').grid(row=8, column=1, sticky="NSEW")
         # locally initialize ammo count down
        self.counter = tk.IntVar()
        self.counter.set(INITIAL_COUNTER_VALUE)
        # locally sets the timer count down at 100%
        self.timer = tk.IntVar()
        self.timer.set(INITIAL_TIMER_VALUE)
        # locally sets rmbar to 0%
        self.rmcount = tk.IntVar()
        self.rmcount.set(RMMAX)
        # locally sets tempbar
        self.temperature = tk.IntVar()
        self.temperature.set(TEMP_INITIAL)
        # locally sets text string for ammo status button
        self.stat = tk.StringVar()
        self.stat.set(STATUS)
        self.cooldown = tk.IntVar()
        self.stat.set(COOLED)
        self.gun.set(GUN)
        # this arranges the grid row and column groupings.
        tk.Grid.rowconfigure(self, 0, weight=1, uniform='c')
        tk.Grid.columnconfigure(self, 3, weight=1, uniform='a')
        tk.Grid.columnconfigure(self, 4, weight=1, uniform='a')
        tk.Grid.columnconfigure(self, 5, weight=1, uniform='a')
        # these are the button and label declarations
        rounds = tk.Label(self, justify=tk.CENTER, textvariable=self.counter)
        rounds.grid(row=3, column=2, columnspan=1, sticky="EW")
        label1 = tk.Label(self, textvariable=self.timer)
        label1.grid(row=7, column=2, sticky="EW")
        temp = tk.Button(self,justify=tk.CENTER,text="Temp",bg='black', fg='yellow', highlightbackground='yellow', highlightcolor='black',activebackground='yellow')
        temp.grid(row=2,column=4,sticky="NSEW")
        rm = tk.Button(self,justify=tk.CENTER,text="R(M)",bg='black', fg='yellow', highlightbackground='yellow', highlightcolor='black',activebackground='yellow')
        rm.grid(row=2,column=5,sticky="NSEW")
        # rounds rate bar
        rmbar = ttk.Progressbar(self, orient="vertical", variable=self.rmcount)
        rmbar.grid(row=3,column=5,rowspan=6, sticky="NS")
        # temperature bar
        tempbar = ttk.Progressbar(self, orient="vertical", variable=self.temperature)
        tempbar.grid(row=3,column=4,rowspan=6,sticky="NS")
        # declarative buttons
        timestat = tk.Button(self,bg='black',state=tk.DISABLED, fg='yellow',disabledforeground='yellow',highlightbackground='yellow',borderwidth=2,justify=tk.CENTER,text="TIME AT 100% \n (msecs)")
        timestat.grid(row=7,column=0,columnspan=2,sticky="NSEW")
        roundsr = tk.Button(self,bg='black',state=tk.DISABLED, fg='yellow',disabledforeground='yellow',highlightbackground='yellow',borderwidth=2,justify=tk.CENTER,text="Rounds \n Remaining")
        roundsr.grid(row=3,column=0,columnspan=2,sticky="NS")
        # crit menu bar
        crit = tk.Button(self,justify=tk.CENTER,textvariable=self.stat, bg='black', fg='yellow', highlightbackground='yellow', highlightcolor='black',activebackground='yellow')
        crit.grid(row=5,column=0,columnspan=2,sticky="NSEW")
        # static center header
        headernew = tk.Button(self, bg='black',state=tk.DISABLED,justify=tk.CENTER, text="UA 571-C \n REMOTE SENTRY WEAPON SYSTEM")
        headernew.grid(row=0,column=1,columnspan=4,rowspan=2,sticky="NSEW")
        gun_1.grid(row=0,column=0,rowspan=2,sticky="NS")
        gun_2.grid(row=0,column=5,rowspan=2,sticky="NS")
        # these are the attachments for input from keyboard into the application
        # These are the button inputs from the original flash app that were used
        # I added a q as well to quit and close window in case there was a need to close
        self.bind("<KeyPress-f>", self.on_keypress_f)
        self.bind("<KeyRelease-f>", self.on_keyrelease_f)
    def coolbar(self):
        temperature_count = self.temperature.get()
        if temperature_count >= 21:
          temperature_count = temperature_count-1 or TEMP_INITIAL
          self.temperature.set(temperature_count)
          print("key not pressed", temperature_count)
          self.after(300, self.coolbar)
    def overheat(self):
        rmcount_count = self.rmcount.get()
        rmcount_count = 0
        self.rmcount.set(rmcount_count)
        state_stat = self.stat.get()
        state_stat = "OVERHEAT"
        self.stat.set(state_stat)
        playsound("warning1.mp3")
        time.sleep(0.7)
    def critical(self):
        counter_value = self.counter.get()
        if counter_value <= 50:
          state_stat = "CRITICAL"
          print("ammo CRIT", counter_value)
    def out(self):
        if counter_value == 1:
          state_stat = "OUT"
    def reload(self):
        if counter_value >= 1:
          state_stat = ""
    # this defines the fire ammo count down sequence and resets
    def on_keypress_f(self, evet):
        counter_value = counter_value-1 or INITIAL_COUNTER_VALUE
        self.counter.set(counter_value)
        # this is logic to try and get ammo warnings
        self.reload()
        self.critical()
        self.out()
        # this sets the time at 100%
        timer_value = self.timer.get()
        timer_value = timer_value-66 or INITIAL_TIMER_VALUE
        self.timer.set(timer_value)
        # this sets the rmbar to 40%
        rmcount_count = 40
        # this sets the temperature
        temperature_count = temperature_count+1
        if temperature_count == 90:
          self.coolbar()
          self.overheat()
        else:
          state_stat = ""
    def on_keyrelease_f(self, evet):
        #this adds logic to say rate is zero if not firing
        #this automatically turns off rate bar moment key is released fixing a logic issue
        rmcount_count = 0
        if temperature_count >= 20:
          self.coolbar()
        self.withdraw()
        self.deiconify()
        self.withdraw()
        self.deiconify()
    def kudos(self):
        self.withdraw()
        self.deiconify()
        print("k pressed")
        self.kudos()
        self.destroy()
        self.on_button()
        self.destroy()
        self.quit()
    # this sets the gun terminal identification
    # this can also be expanded to do other things if you want to alter the script
        which_gun = "A"
        which_gun = "B"
        which_gun = "C"
        which_gun = "D"
# End fire menu class and related functions
#Begin secret credits(kudos) screen
class KudosFrame(tk.Toplevel):
        self.title("Secret credits screen")
        r0c0 = tk.Button(self, text='Close', command=self.destroy, bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        r0c0.grid(row=0, column=0, sticky="NSEW")
        r1c0 = tk.Label(self, text ='Alienslegacy.com Credits \n knoxvilles_joker aka gabriel vos new script  \n martinr1000 font and some coding help \n MLR 2007 for original flash script \n Facebook.com  theuscm \n youtube.com/channel/UC4KYYScA5WcdCZeiU6lcjdA \n cobra_shipwreck channel aka knoxvilles_joker', bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        r1c0.grid(row=1, column=0, sticky="NSEW")
        r1c1 = tk.Label(self, text =' ', bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        r1c1.grid(row=1, column=1, sticky="NSEW")
        r0c1 = tk.Label(self, text ='Python-forum.io credits \n Yoriz coding pointers and help \n ndc85430 coding critique \n ', bg='black', fg='yellow',highlightbackground='yellow', highlightcolor='black', activebackground='yellow')
        r0c1.grid(row=0, column=1, sticky="NSEW")
        self.withdraw()
        self.deiconify()
    def kudos(self):
        self.withdraw()
        self.deiconify()
        self.withdraw()
        self.deiconify()
        self.destroy()
        self.create_splashframe # this appears to launch the initial window
        self.withdraw()
        self.deiconify()
        print("k pressed")
        self.kudos()
        self.on_button()
        self.destroy()
        self.quit()
# End secret credits(kudos) screen
# The below two commands run the entire script
tk_app = TkApp()
tk_app.mainloop()
still slowly progressing on this.
Python:
#import PIL.ImageTk
#import image
#import PIL
#import PIL.Image
import time
import os
GUN = ""
#sets gun rate
RMMAX = 0
TEMP_INITIAL = 20
STATUS = ""
COOLED = 20
# this defines the splash frame
    def __init__(splash, *args, **kwargs):
        splash.geometry('512x256')
        splash.title("Inititaling")
        splash.configure(background='black')
        splash.overrideredirect(True)
        splash.after(3000, splash.destroy)
        tk.Grid.rowconfigure(splash, 0, weight=1, uniform='a')
        tk.Grid.rowconfigure(splash, 1, weight=1, uniform='b')
        tk.Grid.rowconfigure(splash, 2, weight=1, uniform='b')
        tk.Grid.rowconfigure(splash, 3, weight=1, uniform='b')
        tk.Grid.rowconfigure(splash, 4, weight=1, uniform='b')
        tk.Grid.rowconfigure(splash, 5, weight=1, uniform='b')
        tk.Grid.rowconfigure(splash, 6, weight=1, uniform='b')
        tk.Grid.columnconfigure(splash, 0, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 1, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 2, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 3, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 4, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 5, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 6, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 7, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 8, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 9, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 10, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 11, weight=1, uniform='d')
        tk.Grid.columnconfigure(splash, 12, weight=1, uniform='d')
#('winnative', 'clam', 'alt', 'default', 'classic', 'vista', 'xpnative')
        styled.theme_use('default')
        styled.configure("TLabel", background='black', darkcolor='black', bordercolor='black', relief='none', lightcolor='black', highlightcolor='black', throughcolor='black', foreground='black', shiftrelief=-5, highlightthickness=0, width=0, anchor="NSEW")
        loadingbar = ttk.Progressbar(splash, style="Horizontal.TProgressbar", orient="horizontal", length = 50, mode='indeterminate', maximum=100)
        loadingbar.grid(row=4, column=4, columnspan=2, sticky="NEW")
        loadingbar.start([48])
        tk.Label(splash, text="SYSTEM INITIALIZING", bg='black', fg='yellow', font="sentryTerminalfi 6").grid(row=3, column=4, columnspan=2, sticky="SEW")
        tk.Button(splash, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', highlightthickness=0, bd=0, borderwidth=0, justify=tk.CENTER, text="UA 571-C \n REMOTE SENTRY WEAPON SYSTEM", font="sentryTerminalfi 12").grid(row=2, column=2, columnspan=6, sticky="NEWS")
        splash.canvas = tk.Canvas(splash, width=50, height=50, bg='black', highlightthickness=0)
        splash.canvas.create_line(5,5,50,5, fill='yellow')
        splash.canvas.create_line(5,5,5,50, fill='yellow')
        splash.canvas.grid(row=0, column=0, rowspan=2, columnspan=2)
        splash.canvasright = tk.Canvas(splash, width=50, height=50, bg='black', highlightthickness=0)
        splash.canvasright.create_line(5,5,45,5, fill='yellow')
        splash.canvasright.create_line(45,5,45,45, fill='yellow')
        splash.canvasright.grid(row=0, column=11, rowspan=2, columnspan=2)
        splash.canvasbotright = tk.Canvas(splash, width=50, height=50, bg='black', highlightthickness=0)
        splash.canvasbotright.create_line(5,45,45,45, fill='yellow')
        splash.canvasbotright.create_line(45,5,45,45, fill='yellow')
        splash.canvasbotright.create_text(22,27, fill='yellow', text="  28R \n LM 12", justify=tk.RIGHT, font="sentryTerminalfi 8")
        splash.canvasbotright.grid(row=5, column=11, rowspan=2, columnspan=2)
        splash.canvasbotleft = tk.Canvas(splash, width=50, height=50, bg='black', highlightthickness=0)
        splash.canvasbotleft.create_line(5,45,45,45, fill='yellow')
        splash.canvasbotleft.create_line(5,5,5,45, fill='yellow')
        splash.canvasbotleft.create_text(25, 35, text="V5.48", fill='yellow', font="sentryTerminalfi 6")
        splash.canvasbotleft.grid(row=5, column=0, rowspan=2, columnspan=2)
class TkApp(tk.Tk):
        self.geometry('512x256')
        self.gun.set(GUN)
        # Specify Grid
        gun_1 = tk.Button(self, borderwidth=0,bg='black',fg='yellow',disabledforeground='yellow',state=tk.DISABLED,textvariable=self.gun, highlightcolor = 'yellow')
        self.canvasgun1 = tk.Canvas(self, width=28, height=28, bg='black', highlightthickness=0)
        self.canvasgun1.grid(row=0, column=0)
        self.canvasgun1.create_oval(0,0,27,27,outline='yellow')
      #  self.canvasgun1.create_text(10, 10, fill='yellow')
        self.canvasgun1.itemconfigure(self.gun, text=self.gun, fill='yellow', disabledfill='yellow')
        self.canvasgun1.create_window(28, 28, window=gun_1)
        gun_2 = tk.Button(self, borderwidth=0,bg='black',fg='yellow',disabledforeground='yellow',state=tk.DISABLED,textvariable=self.gun)
        headernew = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=0, justify=CENTER, text="UA         571-C \n REMOTE SENTRY WEAPON SYSTEM")
        syst = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="SYSTEM MODE")
        weap = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="WEAPON STATUS")
        iff = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="IFF STATUS")
        test = tk.Button(self, bg='black', state=tk.DISABLED, fg='yellow', disabledforeground='yellow',highlightbackground='yellow', borderwidth=2, justify=CENTER, text="TEST ROUTINE")
        gun_1.grid(row=0, column=0, sticky=W)
        if first_selected:
        else:
       group.rotate(-1)
       group.rotate(1)
        self.withdraw()
        self.deiconify()
        self.withdraw()
        self.deiconify()
    def kudos(self):
        self.withdraw()
        self.deiconify()
        print("k pressed")
        self.kudos()
    # these work
        which_gun = "A"
        which_gun = "B"
        which_gun = "C"
        which_gun = "D"
        self.on_button()
        self.quit()
        self.destroy()
        self.__init__()
        self.gun.set(GUN)
        styled.configure("Vertical.TProgressbar", foreground = 'black', background = 'yellow', bordercolor='black', darkcolor='black', throughcolor='black', lightcolor='black')
        # rounds rate bar
        # temperature bar
 # crit menu bar
        headernew = tk.Button(self, bg='black',state=tk.DISABLED,justify=tk.CENTER, text="UA 571-C \n REMOTE SENTRY WEAPON SYSTEM", borderwidth=0, fg='yellow', disabledforeground='yellow')
    def coolbar(self):
    def overheat(self):
        rmcount_count = 0
    def critical(self):
    def out(self):
          state_stat = "OUT"
    def reload(self):
          state_stat = ""
        self.reload()
        self.critical()
        self.out()
        rmcount_count = 40
          self.coolbar()
          self.overheat()
        else:
          state_stat = ""
        rmcount_count = 0
          self.coolbar()
        self.withdraw()
        self.deiconify()
    def kudos(self):
        self.withdraw()
        self.deiconify()
        print("k pressed")
        self.kudos()
        self.destroy()
        self.on_button()
        self.destroy()
        self.quit()
        which_gun = "A"
        which_gun = "B"
        which_gun = "C"
        which_gun = "D"
        self.withdraw()
        self.deiconify()
    def kudos(self):
        self.withdraw()
        self.deiconify()
        self.destroy()
        print("r pressed")
        self.destroy()
  #      self.create_splashframe
        print("k pressed")
        self.kudos()
        self.on_button()
        self.destroy()
        self.quit()
tk_app = TkApp()
tk_app.mainloop()
