superjedi
Hi all,
I'm trying to get some input on primers to use on resin kits.
I recently picked up a resin gun model and had used Tamiya surface primer as my base coat. I had to mask some areas off when spraying my top coat, and when I took off the tape, it just peeled everything down to bare resin. :confused
I'm no stranger to resin kits. I've built many of them before, using exactly the same materials and techniques. I'm a big fan of Tamiya paints. They lay down extremely smooth, and I've never had any problems with them adhering before, even on resin.
I've stripped the model back down to bare resin all over, and I want to try a different primer this week sometime. What have you used with good results? I've heard of 'self-etching' primers. Do they bond better with resin type plastics? Speaking of plastic, has anyone tried the Krylon Fusion on resin? Good? Bad?
Appreciate any advice!
Eric
Eric
