Predator Replica Combi Stick with counter + Gauntlet With counter
Xenomorph666
Ok sorta a work in progress installed the working counter which required modifying the original design somewhat working with a friend to try and make it screen acurate and need to work on the painting.
Raw just primed with a metalic caramel color to find defects.
End closest to the counter has been screwed in place a 9volt battery inside a cavity behind it. The counter counts down in random sequence just like the original hero prop.
Re: Predator Replica Combi Stick with working counter
the counter looks wicked. Is that a button to start the counter or an on/off switch? if its on does it just run non-stop
Thats looking pretty cool, well done, love predator stuff
Very nice start! Looking forward to seeing this one finished!
Can't go wrong with Pred gear! Looking sharp (no pun intended)!
Its an on off switch so the combi counter runs continous until turned off running in random sequences like the original prop. Now im not sure on this but I always took that counter as a power source and possible detonation device but I was never sure.
I also have my Gauntlet rigged with a similiar counter than I can configure the sequence with my computer. I could do that with the combi but to access the board and port would be to difficult at this point and I have it set in an acurate enough sequence.
Thanks for all the kind words will keep the pics comming as progress develops. Im thinking of having a friend paint this because I have so little free time. So it might be finished sooner rather than later.
Heres my gauntlet in action
And heres another picture of the combi as I originally recieved it
