squirk
I am building a Doc Ock costume for my son for Halloween, and I am using a combination of plastic pool hoses, PVC and craft foam for the arm assembly and belt.
Based on Tjack's guidance, I will use some heavy gauge wire to shape the arms, so I don't expect them to flop around too much, but I still think I need a flexible paint just in case we want/need to modify the arms after painting. I also need a flexible paint for the craft-foam belt, too.
FlexiDip makes a darker gunmetal gray which is OK. PlastiDip makes a metallic aluminum, which might look better. However, I am not sure if one will work better than the other for my purposes. Which, if either, will work better in terms of adhesion and crack/flake resistance on both the plastic pool hoses AND the craft foam? Ideally, I would like to use just one color to match all the various cybernetic pieces.
Thank you!
Thank you!
