Painting and project advice needed. Cthulhu Embryo
hydin
A friend of mine wants me to make him a Cthulhu embryo in a jar, and while it would be sort of easy to do, I have no idea how to paint it. I figured it would make an interesting distraction from the last week, so I am hoping to start it this weekend.
The idea is just an old specimen jar like you would see in a museum or grandpa's old attic. If grandpa was really really creepy and kept things like that in the attic.
I was thinking sculpy to make the body and tentacles over a wire frame, maybe a little foam sculpting for the body and octopus head. I might hit wal mart to see if they have something squidlike in the aquarium area (plastic, not live).
It will be put in a sealed jar (probably a clear plastic jar or old glass jar), and sealed with "lead" (also known as sculpy that has been painted silver/black or hit with rub n buff).
Obviously I can't use acrylics to paint it since it will end up washing off in the water, but I can't think of anything that will not get affected by the water. I don't know if sculpy holds up under alcohol, but that is always an option to use instead of water...
Not sure about regular enamel spray paints, but since I never painted anything that was going to stay in the water, this is a new realm for me.
So... any ideas on this? It should be a pretty easy project to knock out, but while I have the basic stuff figured out I am a little bit lost on the more detailed parts of it.
The idea is to avoid resin, silicone, etc. Total project funds = ~15$.
Some stuff I already have access too :
Plaster
Durhams Water Putty
Some foam pieces
Belt Sander
Power drill/dremel
Sculpy (light? I guess it's 1/3rd the calories :p )
Alchohol
Water
Tea bags (to dye water)
Any helps appreciated. I figure I would take a few WIP pics and just sort of document the project if anyone else wanted to make one.
Actually, you may be able to paint it in acrylics, if that's what you have handy.
What you need to do, is after you paint it, is give it a few coats of Future Floor Wax (now sold as Pledge with Future shine). Once the Future dries, it's impervious to everything except ammonia.
So paint it, let it dry fully. Then dunk it in a jar of future (best way to get full coverage) take it out and let it dry overnight. Then give it a second dunk and let that cure for 3 days. That'll guarantee that it's fully cured. Then you can put it in water without worry.
-Fred
Cool! I still have a bottle of that stuff from years ago. Nothing better for getting a nice clear finish on a clear piece of resin :)
Stuff lasts forever too...
I will give it a try tomorrow afternoon. Just gotta build a little rig to hold the little guy up while he dries off :)
I'd really like to see this when you are done. I'm a Lovecraft nut (note the avatar). I made myself some Cthulhu skin in a specimen jar using Salmon skin that I had saved and dried and then dyed in a glass of green Easter egg dye. Then I put it in a jar of alcohol and sealed it with wax. It looked friggin' awesome. I even made a label in Photoshop. Sadly I gave it to my Creative Writing professor (who is also a horror author and Lovecraftian fan) when I moved.
Also, contec, your link does not work for me.
