DukeNukem117
Hmmm, interesting. I never liked taping myself back when I did careplans for nursing (a whole other life), so I'm going to look on craigslist for an old large scale printer just for BPs.
Anyways, progress update (11-26-11, 19 days left)
I didn't do much over the last 2 days on account of thanksgiving. The main body part has been cut out with a bandsaw. Some further detailing in the cuts needs to be done, and I'm going to start sanding for symmetry starting tomorrow or monday, then router the edges. The side panels will be designed and cut into acrylic with a laser cutter. I thought styrene or sintra might be easier to paint over, but thats what my shop teacher said to use.
As you can see, I've gotten alot of the electronics in the mail, and am sorting through how to make it all work. The CCFL does have a large footprint, but the rod is the perfect size, so I'll see if I can make it work before turning towards LED/acrylic tube.
Few things that I'm still undecided on:
1) The trigger guard slot - I'm not sure if I should try using the milling machine to cut this out. The MDF is too thick to use a scroll saw, so a jig-saw might be the best way, then I smoothen it out with putty. I'm not too experienced with jig saws, so I dont know how much kickback or control it has. Another option is to simply drill a ton of holes. Lastly, should I cut each separately or clamp the two MDFs together for a better shot at symmetry? Its going to clamp together to be 1.5 inches thick.
2) The trigger - A static trigger would be extremely easy to do, but a moving one would obviously be better. However a moving one would take much more time, as I would need to cut a slot between the two thick pieces of MDF, and cram a trigger, spring, and possibly hinge in there. Since I dont have the time to wire the trigger to interact with the lights, it would simply be there to press. I'm not sure if the trade-off is worth it for how much additional time it will take. Is there a way to "cheat" a trigger function that is much easier and less complicated that I don't know about?
Thanks, and I hope you all had a great Thanksgiving!
