HI all
I want to make a complex tube assembly for a costume with a israeli gas mask. The mask filter thread is a standard 40mm, and so I want to use the standard metal connector from these tubes:
But I want to use a different tube - like those for washing machines. I think they come in 25mm, 32mm and 40mm diameters. Not sure if this is inner or outer diameter.
Does anyone know what is the diameter of the metal tube connector (the part that is hidden inside the tube above?)
so I can find out what tube diameter I need to fit onto these metal connectors.
