Need Advice on a Studio
Eric Ladd
My wife and I have bought a new house and will take ownership when construction is complete February of next year. The unfinished basement is mine to create what ever I want. I haven't been modeling in a long time, due mostly to lack of space and only in the last year have I discovered the studio scale genre. Baby, I am hooked!
Some of you guys have worked on movies and some of you are just fans that have talent. My plea for advice is this:
I have a blank canvas to create a scratch building work space . What do you consider the essential tools and materials to have onhand? What are the "nice to have" items and what are the things you can do without, but are sweet if you can afford them?
Right now my concern is scratch building. I may eventually get into molds making and kit production, but my focus for now is scratch building.
Thanks for your time and energy in response.
Eric Ladd
Man I wish I had this situation in my life congrats
  1. Airbrush
  2. Airtank
  3. Paint Booth that vents out basement window
  4. standing drill press
  5. mouse sander
  6. belt sander
  7. dremel
  8. long bench
  9. shop vac
Man the list could go on and on but these are the things I use most all the time.
As for nice to have
Big sink with full plumbing
Big Screen TV :)
Greg
to the above list I'd add:
  1. Dremel bits lots of sanding bits and carving bits
  2. clamps various sizes
  3. good paintbrushes
  4. crappy paint brushes
  5. sand paper - course and fine grits (I guess this might be implied by the mouse and belt sander above but I like to do some stuff - a lot actually but hand
  6. mixing jars for paints
  7. Masking tape various widths
  8. Vice
  9. Xacto knife with lots of blades
  10. Self healing cutting pad.
  11. Calipers
  12. rulers, measureing tape etc.
  13. magnifying glass of some kind
  14. various epoxies, CA glues, and adhesives
  15. something to organize your paints
  16. A nearby window or outside facing door with a fan to blow fumes out :eek
  17. A side table that is not your workbench for placing stuff down... I find my workbench gets cluttered after workign for an hour or so and I always need another place to put domething. this is usually the remider I need to stop building and sort things back to where they belong
  18. A comfortable chair/stool - depending on your preferred working position.
I think that's enough for now - and should keep your credit card nice and warm :lol
Jedi Dade
Welcome back to the hobby! :)
Ventilation. This is often overlooked, especially when working in a basement or other interior space. (You need good ventilation even when working in a garage.)
Since you'll be working with a lot of chemicals ranging from mildly toxic to downright noxious, you will need a constant supply of fresh air. Seal the basement off from the rest of the house with an exterior grade door and then provide a way to change the air in the area many times an hour. You'll still need to wear a respirator for some operations and you may also need a way to remove fumes directly from a local area.
An energy recovery ventilator (ERV) can change the air in the basement while pre-conditioning the incoming air so you don't lose heat and/or air conditioning. They aren't cheap by any means, but how much is your health worth? In addition, install a dryer vent and hose with some sort of inline fan to pull fumes away from your immediate work area when you get out the toxic glue, fillers, etc.
Just about all the materials, compounds, and other stuff we modelers come into contact with these days is toxic in one way or another. Some people actually get sick from prolonged exposure. So, it's worth the extra effort to protect yourself. . .
Thanks for the advice, gentlemen. I appreciate it greatly.
Eric,
One thing that I didn't see mentioned was atmosphere. No not just fresh air in the room. What I'm talking about is to make it a nice place to be. Being in a basement one thing you'll be in need of is light, not just task lighting and overhead lighting and other electrical lights, a white or light colored type drop ceiling and light colored walls. These will help alot more than you think and while you have nothing in the way it easier than to retro fit latter.
Happy Modeling!!!
-JohnLogan:lol
Speaking of task lighting... I thought that my CC D7 was in pretty good shape until I turned on the 1000watt Halogen worklights... Yikes I was in for another round of careful filling sanding, and priming before paint. High intensity light shows every imperfection. So yeah a $10-30 investment in some really Frakking bright lights... very worthwhile. Mind you I do not usually work under them - but I do "check my work" under them :thumbsup
Jedi Dade
Sounds like a good idea. I got the builder to add an ERV and an air purifying system to the plans yesterday. I won't be able to get into the space until February to start "nesting", but pre-wiring the house with CAT-5, extra electrical outlets, etc. is nice at this stage. The thing I like the most is having a blank slate to build my space. I should have ample room for shelving, organizing tools, etc. It will be a slow build up, but I should have a very nice work space this time next year.
I hear a lot of people talking about a lazer cutter. I am assuming this is for precision styren cuts and patterns, but I am not sure. Anyone care to enlighten me?
Thanks for all the advice again.
Just be sure the basement is as tight as possible so that no fumes can get into the rest of the house. For example, the basement would be a VERY bad spot for a forced-air return. Your furnace or A/C would "inhale" the fumes and distribute them to the whole house! :eek
Don't forget an exhaust fan for fume extraction over your bench or for a paint booth. This is very easy/cheap to add at this stage, but could be a pain after the fact. . . :)
Make sure the basement is on it's own circuit(s). Nothing worse than turning on too many tools and taking down half the house with you. And have plenty of outlets at all of your stations.
Also, besides all the ventilation, make sure you have heating, air conditioning and a dehumidifier. Nothing makes working more miserable than either being too hot or too cold. And too much humidity will kill a paintjob in the blink of an eye.
As for lighting, try and get as many daylight temperature bulbs as possible. Nothing throws off color perception worse than incandescent and flourescent bulbs.
You'll also want some of those arm-mounted magnifying/light combos. This way, you don't need to try and get a magnifying glass and propper lighting all into a little confined area where you're trying to work.
-Fred
yeah..
at this stage, i feel like you're wanting to know about the room....not necessarily what tools to buy (dremel, air compressor, etc). along the way you will slowly accumulate these.
my ideas (some mentioned so far, some not)
lights: i have halogens. they are hot little devils, but only close up. and they give nice several nice foot candles of white light. i have some small guy with a few hockey puck lights...along with four flex arm desk lamps. these are helpful for modeling purposes, but may need different light angles when you decide to photograph your pieces.
closet space: you'll end up accumulating lots of stuff. lots of tools. lots of kits. your place will feel much more clean and productive if the stuff you typically don't use is tucked away in a closet (but should be easy to get to). shelves are nice....but too many shelves end up looking like a flea market or your crazy grandma's kitchen.
table space: layout area is a must. sometimes you'll have a kit in the middle of construction, another one in the midst of painting. and you'll want some extra area just to throw down material---be it a new kit you just bought, some research material, or your laptop.
foot switches. these are my favorite trick. little step switches (can get them at wal-mart fairly cheap. hook your air compressor into it-so you don't have to reach down while trying to balance your airbrush. hook all the lights (of one station -- painting or construction) into one of these....its a lot easier then hardwiring. no forethought...and no worries about resell value.
empty walls. this is akin to the closet space. in art, negative space can be just as important. as well. this space may be used for some kick ass poster...or future display cabinet that you haven't found yet.
chair. DO...NOT...SKIMP...ON ...THE CHAIR. your ass will thank you later. i spent a couple weeks driving around town lookign for mine...and paid nicely for it. it should have wheels. it should have a little reclining. it should have arms. and it should tear easy (in case you drop a blade or hot chemical on it) like some webbing like chairs nowadays
floor. this may be common sense, but fear carpet. go with a tile. or if you can...just keep the concrete floor (if its a poored concrete basement floor). the bare concrete floor will be easy to carpet later (resell value). try to paint the floor something that will show little pieces. something light colored...but not white. your choice.
outlets. code may ask for 12' oc. or 6' from corners.....make it tighter if you can.
glass. this is KINDA a tool, but more environment. i'm always trying to produce nice right angles. nothing does that better than a nice big piece of thick glass along with some machinist squares. wood table tops will never be perfectly flat. this glass comes in handy later also (putting down tape when your cutting exact pieces to mask, or mixing oil paints, etc.
lounging. not sure how much room you have....mine is fairly small. but i still have a second "area". i have another mies low loungy chair, a side table, and a reading lamp. sometimes you just want to push away from the work bench, but yet still read some modeling material....and maybe have your laptop or movie going on nearby. your mancave doesn't have to be 100% modeling. besides if you have your wife/gf/whoever come visit you...they shouldn't feel like they HAVE to leave. this extra area is a "low traffic" area where "civilians" can sit on the sideline.
bins. i have these in the closet and under tables. you'll find out that everything you accumulate will not fit nicely onto a shelf. i have lots of scratchbuilding greeblies, small batches of rtv/resin, tools,...just sitting in bins. these bins are usually in the 8"tall, 24" deep, 18" range...and stacked 3 high. also have your smaller bins nearby ...on your tables. these can hold your more frequently used, and smaller items.....paints, sandpapers, airbrushes & tools,
paper. i make a mess. i actually got some nice office furniture, but i laydown some cheap paper down. here its called painters paper. looks like the paper that paper bags (from your grocery store) are made of. you can get it at lowes/h'depot for a few dollars for a big roll. it keep things tidy (from paint, dust, solvents) and easily removable (i usually just tape mine to the table).
i hope this helps.
quincy
