Metro 2033/Last Light - Need Help with Metro Items to make Props
Citpo
What with the release of the Metro 2033 and Last Light redux it has inspired me to try my own take on the Ranger of he Order/Spartan outfit seen all over D6 in-game. However, alot of the posts I find are rather "dated" and I find alot of the links to items are either dead links or simply don't exist in the store search, mainly the following items:
- Universal Charger motor and other assorted parts attached to it
- Orange civilian medkit
- Custom Spartan patches/someone who can make them/the know how on how to make them.
Any help/thread referrals will be greatly appreciated.
The medkit would probably russian surplus, the custom charger would be best build using 1980's era electronic components. The charging motor can be adapted from a mechanically powered flashlight. I only know the dutch name for these but its called a "knijpkat". An image search might help.
I did some more research and found that the motor was from some old Russian sewing machine, However it's alot bigger than the game model so I might custom make my own one. But everything else sounds good so far, thanks gov.
From what I remember from the game, the internal parts of the motor are not visible, so all you have to focus on is the housing. You should be able to re-create the housing out of any round object. In the past I have used anything from tin cans to PVC pipes to create round objects like that.
hey guys! don't know if this till is active but im looking into building the charger from metro last light/2033 i don't know which yet. i have some ideas for it. but i recently discovered that the red handle part on the charger really looks like a fire extinguisher handle. what do you guys think
Looks very similar, You would have to add a small spring mechanism since fire extinguisher have pressure to provide feedback on the handle. The charger looks like any generic alternator or motor from the 80's and the block below looks like an exposed transformer.
I have had a root on my HDD for you. I have exported the first aid kit + handcrank to .pdo format (pepakura designer). You should be able to see them now (if you have/use that program), but also I have added the textures to the files, so now you also have those for reference.
http://www.4shared.com/file/q8lotClXce/Metro2023_First_Aid.html
http://www.4shared.com/file/KDFflrj_ba/Metro2033_Handcrank.html
blue2k, THANK YOU VERY MUCH for sharing the .pdo files. Would it be possible for you to share the raw texture map? I'd like to have it so I can remap the .obj in 3D Max. That way I can rebuild the details more accurately before I 3D print a replica.
Thanks,
Brian
Thanks,
Brian
Here are the full missing textures, sorry for the delay. I have only just noticed this thread had a reply.
  • missing_full_textures.zip
No worries! Thanks for sharing those! As usual, I'm behind the curve on genres that I'm making props from, but it is an awesome game! I've decided to delay making the charger until after Dragon Con, but I've 3D printed most of it now, and the textures will be very helpful in making my final prop.
Thanks,
Brian
Are you willing to share those 3d print files for the medkit ?
