Lifeburn
Well I'm trying my hand at making the M8 Avenger from the Mass Effect games to go with my newly aquired N7 armor. For this build I'm using EVA foam entirely. First of all for those who don't know what this rifle looks like this is it.
I found some templates of the side.
I then traced the template onto a sheet of EVA foam.
I cut out two copies and glued them together, I put long pieces of a piano hinge in between to give the gun some weight and rigidness.
I then modified the templates and cut out two more copies.
This is where I stopped.
Next will be sanding down the outer layers of foam to get the shape of the gun. I'll be doing that over the next day or two. Anyone know what I can use to cover up the seams on the edges of the gun?
