Making a spaceship
Pippspriller
We started designing texture pieces for the walls
Sent from my iPad using Tapatalk
Here's the transporter emitter and the light engine effect. We used bits from a "water ripple effect" light engine and used a stronger RGBW LED to make it more dramatic. The transporter pad is an aluminum disk attached to the floor
Here's a still image of the beam
Going for a bit of a Star Trek look, we made consoles for Command, Engineering, and Science / Navigation officers
One of the consoles is "broken" and needs to be hotwired
Three doors for 1) Transporter Room. 2) Bridge and 3) Shuttle Bay
I took this shot so you could see all the etching on the display screens and console tops. The displays have two layers of acrylic so it can display info in two colors at the same time
Data fields lit...
Basecoat paint done (this one is going to be a clean ship so, no coolant or oil drips)
Reactor cores... used to power up the reactors on the main deck. Not really a puzzle, simply a task players need to figure out and perform.
Extraordinary. That is one of the most extensive builds I've seen. Large scale props are awesome !
