I posted this low cost alternative over at Rebelscum and thought I'd also share it here
You'll need the items pictured below... A pack of adhesive picture hangers, a pack of clear tiny rubber bands, and loose key rings (one for each saber hilt... the 2" ring fits the ANH Vader and Luke ROTJ nicely).
Now, measure and mount the lower hanger, following the directions on the hangers' package...
Once the lower hanger is mounted, measure up and afix the upper hanger for the blade.
Then slide the key ring over the lower hanger...
The hilt fits in like so...
Now, slide a couple rubber bands over the top of the blade and into the upper hanger (I recommend using at least two rubber bands for a secure hold)...
And there you have it...
The sabers can easily be pulled off the wall for play. You may have to replace the rubber bands every now and then, but you get plenty in a pack
Hope that helps.
Hope that helps.
