LED Resistors
jvasilatos
I forgot what type of resistor I used for LEDs on one of my buildups, and need more but can't tear open the other model to see what I had (if I could even read the microscopic text)... can someone let me know what is the recommended type of resistor for Radio Shack LEDs? Non blinking sub miniature (smallest kind...) need to use them for the engines on my Vader TIE.
JV
<div class='quotetop'>(jvasilatos @ Jun 16 2006, 12:36 PM) [snapback]1262709[/snapback]</div>
JV
[/b]
What is the max voltage and mA the LEDs run off of? Also, what is the voltage of the power source?
G
3 triple A batteries powering 4 of these:
http://www.radioshack.com/family/index.jsp...2032058.2032233
3mm Red LED
Model: 2760026 | Catalog #: 276-026
Use with electronic devices. Typical MCD is 5.0. This 3mm Red LED has a typical wavelength of 700nm.
* Size is T1 or 3mm
* Red lens color
* Viewing angle is 25°
* 28mA (max)
* Typical Voltage is 2.25, with a maximum voltage of 2.6V
They have resistors on this page but I am not sure which I will need:
http://www.radioshack.com/search/index.jsp...rigkw=resistors
JV
Also I am assuming each will be wired individually to the red and black (called parallel) instead of the positive of one led wired to the negative of the next in series (called series). The general recomendation is to give each LED it's own resistor.
<div class='quotetop'>(WookieGunner @ Jun 16 2006, 09:53 PM) [snapback]1262845[/snapback]</div>
[/b]
Thanks guys-
I was able to get away with one resistor last time for two LED engine lights, I will go with your recommendation though and do one resistor per light this time.
JV
