Jedi Utility pouches measurements help.
seelsa73
Ok, so I'm going to be attempting a set of Jedi belt pouches for myself, and I have been searching far and wide for measurements/dimensions for them and have come up with diddly squat. I'm hoping someone(s) here will know this information. I can't find any good reference photo's of the screen used ones that I'm looking to recreate, so I'm going to include a pic of the ones created by the rebel agent a while back, just so you know what I'm going for. Thanks in advance for any help.
Re: Measurements help.
I tried a new trick I learned. Wild guess that the metal clips are about 1/4" wide and used that for scaling.
The Staedtler pen caps used for the food tablet canisters are 2 1/16" long and 7/16" dia (length does not include the dome added to the bottom)
Use that as your ruler.
You may want to take a look at this http://www.forum.rebellegion.com/forum/viewtopic.php?t=68376&sid=cc3ee3d3e4d98a7c2a8eed020e9de7f6 and probably change your thread title to something more informative alá "Measurements for Jedi utility belt needed".
I assume you mean the belt width? Taking from publicity stills from RotS of Obi-Wan, that would make the tall pouch just 4.5" tall, if my amateurish scaling is correct. That seems a little short to me.
You can scale them to the covertec belt clip if you find a photo of the belt that shows it. And I do not think that your result is too far off.
