theres a product called hydrospan (i think)
is a firm rubber that you cast in a mould, when set its submerged in water and it grows. works really well
um negative ghost rider.
Hydrospan is horrible. Unless you want to increase the size of a hot wheels car by 150%...this comes from real life usage on my own and another prop maker on these boards (SGB). Its horrid stuff. Doesnt expand right due to different thickness tolerances of the cast piece, time in the water, different expansion rates throughout the piece and it falls apart on itself.
Its expensive stuff, wouldnt want you to waste your money.
I saw a product that is somewhat controllable that you can make a mould and by increasing the "parts" of the material when casting, you'll get a perfectly increased version of the original prototype. If I recall, the item they used in their demo was a scooby doo head. It looked like an enlarged photo of the original mini scooby head. I cannot remember the name of it for the life of me. Perhaps a google search might turn up something.
Dave
i used the hydrospan with great results. granted it was a fairly big sculpt without thinner pieces but i drilled holes on the inside about an inch apart and left it in the water longer than the 2 weeks and it worked perfectly.
you can get it in the uk via another supplier, what do you want to enlarge?
i dont think you should have problems with that. obviously you would need to cap the eyes and mouth, mold it then cast the hydrospan in it.
the uk supplier is a company called european polymer products group.
tel: 01584 877513
email: info@industrialpolymerseuro.com
