Iron Man MK 42 Files HELP!!!!!!
mdashlin117
Hey guys, im new here an want to make a foam suit of the MK 42 armor but im really bad at the scaling, any chance one of you guys has a scaled set of files for a guy my size?
i am 6'1'' around 190-200.
If you are using Jackie's files then this should be a close guideline:
5'=152cm -----------391.7295774545455
5'1=155cm-----------399.4610822727273
5'2=157cm-----------404.6154188181819
5'3=160cm-----------412.3469236363637
5'4=162cm-----------417.5012601818182
5'5=165cm-----------425.232765
5'6=168cm-----------432.9642698181819
5'7=170cm-----------438.1186063636364
5'8=173cm-----------445.8501111818182
5'9=175cm-----------451.0044477272728
5'10=178cm----------458.7359525454546
5'11=180cm----------463.8902890909091
6'=183cm-------------471.621793909091
6'1=185cm-----------476.7761304545455
6'2=188cm-----------484.5076352727273
6'3=190cm-----------489.6619718181819
6'4=193cm-----------497.3934766363637
6'5=196cm-----------505.1249814545455
6'6=198cm-----------510.2793180000001
I did not come up with these values.
just scale them, look at the bottom right corner on pepakura where there's the final build size
