Jaded Monk
The original part was fabbed up by laminating 1 or 2 mil styrene sheets against a circular opening. The hole was later scribed and filed smooth. It is approximately 3" in diameter and 2" high.
I need ideas for how to mass produce this part for a lot no smaller than 10pcs. I don't have a pressure/ vacuum cast set-up and am not in any position to buy a pressure pot or venturi pump right now. I can cast, but I'm concerned about the thin wall.
I've already put up $230 in laser cutting and would much rather not have to figure out funding for another run.
PVC is out as the wall is much too thick. I checked TapPlastics but didn't see anything with a thin enough wall.
Unless... kit builders would be amenable to laminating the styrene themselves and scribing with a provided template.
So... any of you creative geniuses have any thoughts?
Cheers!
JM
Cheers!
JM
