Nador said:Print the pepakura with CARDSTOCK, ALWAYS, first. Depending on your skills, you might as you might not, start over, depending on the building and details, sometimes the Peps are deformed because you didn't build it correctly, and sometimes it doesn't happen
Also, depending which stuff you're more comfortable with, you can either use hot glue or super glue ( I think Elmer's makes some, and LePage )
But as Jarvis said, it's very time consuming and if you don't like how the result, reprint and start over, don't worry about that, it happened to everyone using it![]()
I thought about doing that but someone told me that tape won't survive to fiberglass, but if you tried it many time, well that's a proof that it works hahaLflank said:I've always just use masking tape on all my pepakura. But I always place all the tape on the inside, so I can get a smoother finish on the outside.![]()
Nador said:I thought about doing that but someone told me that tape won't survive to fiberglass, but if you tried it many time, well that's a proof that it works haha![]()
wonko said:I've fiberglassed over masking tape too with no problems. 1 little trick I learned was using cheese cloth instead of the fiberglass cloth/mat. It's not quite as durable, but adds some strength and is easier than using the actual fiberglass cloth. I've even seen people use old t-shirts with success.
Brian
Happy to help! Remember though, it's no good for finished surfaces unless you want to spend hours and hours filling and sanding. On the inside of pep it would work good I think. I haven't tried pep myself, but have more experience with fiberglass than I care to have. Great, versatile stuff, but involves too much sanding, which is my absolute LEAST favorite thing to do.Nador said:Cheese cloth ! Good idea ! and it's cheaper ! Thanks Wonko c:
