How to get model rigging or rope to hang naturally?
RGPFX
Ok, I need to make a steel mill model that has cables hanging in gentle loops with a natural drape to them. Because it is a small scale (1/87) model I need a fine rope or substitute of some kind to simulate the steel cable hanging. I figure that this is very similar to hanging ship rigging on model boats. Any ideas???
RGP
Rigging Thread for model boats can be got in loads of sizes, Not sure where you will get it in the US (Im UK) to get to hang run it over a candle to "Wax" it, it should then hold the shape you want it to hang in.
Or use a thin wash of white glue (Elemer's) in the middle which will stiffen the sstring and give it a little sag. I'm told this technique requires practice.
Use wire instead of thread, shape it, then clear coat it.
i would agree with micdavis on this one.
you can get lenths of steel wire from modelshops (usually)
different thicknesses.
to get thread or the like to hang true and straight might be tricky, even with the white glue method.
z
YOU can also look to guitar strings... they come in a vareity of shapes and textures to get subltely differnet sounds... The also have a "texture" to them some of the time that looks pretty cool. I suppose strings for any stringed instrument would be along the same lines...
Jedi Dade
