Help with Pistol Lanyard Ring.
Sean
I was hoping sombody may know the workings of a lanyard ring for old pistols. The type that swivel. I need the mechanics. What holds them In and allows them to swivel?
The post goes into a hole in the pistol, a pin goes from one side to another across that little groove. The pin keeps it in place and the groove allows it to swivel.
Thank you Grenadeking
I may have to figure something else out as I'm putting It Into a Denix Lemat.
You may be able to buy a complete one off a firearms parts shop for relatively cheap. Depending on how 'usable' you need it, you can probably find a similar kind of loop that's meant to be used as a drawer handle.
Thanks Nitram
I already have the ring. Just need to find out If the trench surrounding the ring. Goes high enough to do what Is mentioned.
And welcome to the RPF.
Sean, judging by the trench as you call it, I believe that a snap ring was used for that particular lanyard ring. You'd need to measure the inside diameter of the trench to sort out the appropriate size of snap ring. You should be able to source some pretty easily at any hardware store. I hope this helps.
Thank you narvik
That was not something I was considering. I have to drill the hole for the lanyard ring to go Into the Lemat. Wouldn't there need to be a lip for the snap ring to work? Not sure how I would drill a hole with a lip Included
Thank you narvik
That was not something I was considering. I have to drill the hole for the lanyard ring to go Into the Lemat. Wouldn't there need to be a lip for the snap ring to work? Not sure how I would cut a hole with a lip Included
You need to measure how thick the bottom section of the pistol grip is and compare that to the distance from the outside bevel to the trench. To use a snap ring you need at least a portion of the trench to be above the level of the pistol frame. If you are using a Denix replica, be careful drilling into the frame. Use a slower speed when drilling so you can avoid to shattering the metal.
You need to measure how thick the bottom section of the pistol grip is and compare that to the distance from the outside bevel to the trench. To use a snap ring you need at least a portion of the trench to be above the level of the pistol frame. If you are using a Denix replica, be careful drilling into the frame. Use a slower speed when drilling so you can avoid to shattering the metal.View attachment 1790559
I can make that work.
Thank you so much.
Totally appreciate the help everyone
Cheers
Sean
