Help with paper size
fireforge1979
I'm not sure if this is the correct place to post this thread, and if it's not I apologize, but I have a question about paper. I am modeling in pep and I only have the letter size card stock paper, but most of my pep files are in A4. I have looked for A4 sized paper at staples and on the internet and I can't find it, am I missing something? Does it exist just at a specialty store online that I can't find? Any help would be greatly appreciated.
ps. I have been setting pep designer from A4 to letter, but I would really like to get A4 card stock if possible.
Thank you
Before you start placing the pieces the way you want them on the screen go to file, print and paper setting the on the new window the first dropdown it says a4 click on it and choose letter, that will do it
Sent from my SPH-L710 using Tapatalk
I don't think you're going to have a lot of luck (assuming you're in the states) finding A4 cardstock. A4 is the european standard for paper, and Tamasoft set pepakura up to default to A4 as well.
I personally have never seen A4 cardstock in a store in the US. You're likely going to be stuck as you have in Designer switching the A4 to letter, then either manually repositioning pieces or using 2d menu>recalculate parts layout and set the margin space to 5mm before selecting OK.
Ooops sorry I didnt read the ps. You knew already lol my bad
