Ghostbusters-- 1:1 Aluminum Proton Gun Replica Build
extreme_too2
And here we are.
I wish my story were more unique or interesting, but like most everyone here on the board, I've wanted a proton pack of my own for, well, my entire life. Literally. And, like most, I've tried my hand at builds over the years. Between my lack of wood-working skills and the unavailability of reliable info, the builds never got very far.
I kept up, though. It was a hell of a transition between Norm Gagnon's old plans and actual measurements from screen-used packs. High school Aaron could have never imagined fiberglass shells being offered en mass.
So, when high-quality aluminum parts finally made it on to the scene, I figured it was time to jump back in. It was time to finally have what four year old me could only dream of.
A few things had changed since my last build attempt. First of all, I was no longer struggling with Algebra II homework, and secondly...I'd met a woman. Well, not just A woman. I'd met THE woman. A ring was still a little down the road but I knew it was coming.
With that in mind, I approached my build as a kind of last hurrah. Sort of a metaphorical end to the stuff I wanted as a kid.
Dumb. Just a dumb notion. But, hey, it sounded good at the time.
I got my name on Umori's list for thrower parts and the game was on.
During the wait for everything, I started in on the hardest decision a Ghosthead building a pack has to make: hero or semi-hero? Of course, each has their draw. The hero is iconic. Its look and ingenuity are still revered. The semi-heros took all of that and built on it in several ways. I love those Makita batteries. Sue me.
In the end, I went with both. A hero approach to a semi-hero pack. All the aluminum of a hero with the looks of a semi. It's a thing.
It took a couple of years, but eventually everything was in hand, and construction started. It was nerve-racking. I was certain I was going to mess a part up. I was convinced I wasn't doing anything as it was supposed to be. And I probably wasn't. But it all turned out fairly well.
REAL PARTS:
Arcolectric Indicators (1 clear & 1 red)
Clippard Barbs
Clippard & Nycoil Tubing (OD 5/32" & 1/4")
Clippard R-701 Valve
GB Fans Hat Light Caps (1 orange & 2 white)
Hex Socket Head Cap Screws (4-40, 6-32, 8-32 & 10-32)
ALUMINUM PARTS:
Umoribawar Gun Box (with welded rear handle & base plate)
GB Fans Gun Knobs
Umoribawar Gun Track (with discs and S-hook)
Umoribawar Heat Sink
Umoribawar Rear Cylinder
Umorbawari Rear Instrument Bar (with access panel)
GB Fans Side Knobs
Umoribawar Trigger Box
Umoribawar Finished Tube (with welded ears & barrel lock)
Umoribawar Front Cylinder
Umoribawar Inner Tube
Umoribawar Trigger Tip (with welded trigger)
Umoribawar Brass Banjos
RESIN PARTS:
Venky Gun Grips
MISCELLANEOUS:
Bobamatt Vinyl Labels
R2Devo Light Kit (with amber bar graph)
Umoribawar Barrel Clear Tube (acrylic)
Umoribawar Green Lever (steel with Clippard green tubing)
Namebrand & GB Fans Rub-down Transfers
Umoribawar Stainless Steel V-Hook (female)
Raw Materials:
There was a spacing issue for the light bar. We'll get to it.
Dry fit:
Finished:
I'm still trying to figure out how to do the tip-springing mechanism along with the rotating handle action, so my front handle can still do this...
I appreciate any critiques and comments. Rip this bitch apart.
- Aaron
Thanks, folks! It means a lot, sincerely.
She should really be something once I get the electronics fully installed.
There should, hopefully, be a couple of updates coming soon.
Thanks again!
Awesome!
Um, I'm not a GB guru so I can't comment on accuracy, but your story is inspirational and that is one helluva build! Keep up the great work!
