Hi all...
I'm new to these forums. I thought I would ask a question to all the modelers out there. I've been modeling since I was a kid, but only rather recently started to really put effort into it. What is a good brush weathering technique you guys know? I realize that air brush is much easier to apply weathering, but I am limited as I can't use an air brush in the small condo I own. So what are some good dry dursh weather techniques? thanks for the replies.
Ryan
Why does living where you are restrict you from using an airbrush? I'm just trying to understand the reason(s) mind you...
The two main weathering techniques done with a brush would be washes and dry brushing. Both of these techniques done slowly and gradually can render a very realistic paint job without ever picking up an airbrush. The airbrush can speed up the process though. However, the airbrush is not always the best tool for weathering, especially if you're needing a more irregular weathering effect.
A wash weather effect is done on a piece to bring out recessed areas like panel lines and whatnot. The paint is thinned down to something along the lines of skim milk or even thinner, and then can be applied to the piece in whatever quantity you're comfortable with. Once the wash has sat for a little bit, you'll then need to go back over areas you want to tremove the paint from to clean up the area. I use alot of Q-tips for this part. The color used, consistancy, and how it's applied is all subjective of course, as how I do it doesnt neccessarily mean that's how the next guy does. The brush style used can vary quite a bit as well depending on the amount of coverage you're looking for, etc..
The brush always stays the same for me though when I'm doing dry-brushing. I pull out my trusty flat chisel brush, dip into whatever color I'm using to weather with, and then proceed to wipe of 90-95% of the paint I just put on the brush. This leaves "dry" paint on the brush, so the first surface it comes in contact with is going to be where it stays. This is probably my favorite technique as sometimes the
Both of these techniques should be done slowly and in stages, otherwise you run the risk of having the weathering looking toy-like and unrealistic.
Hope this helps!
