Futurama Head-in-a-jar help
Zach Brannigan
I need help on making a Head-in-a-jar prop. What materials can be used to make it look accurate? Or is there a jar with a base I could buy somewhere?
thanks
Probably going to be best served by checking out fish tanks, or maybe big glass art vases. The big kind you see in floral shops where people put pine cones or artsy balls in or something. A human head is pretty big, and this is supposed to hold it, a few inches of water above it, not to mention around it.
A foam base would be pretty easy to build, just make an outline with the bottom of the jar on top of some blue or pink foam sheeting, make a larger circle, then cut out a few. Glue em together, and cut out a section of the "inner" foam to hold the jar. You could even wire up some LEDs for the inside or outside lighting if you want.
Can't help you with the head part though.
Chris
What are you going for in terms of the head?
Would a realistic head look odd? Will you sculpt a real-world version of the Futurama style heads?
I'd suggest just taking the mask with you to a pet store or a wal mart or something and holding it up next to the aquariums to see what size you need.
Or, measure the head and check the measurements against where you want to get the aquarium at online.
Chris
WOW!!! Nice Post!Kind Regards.
Based on the image tags I'm going to guess a spam bot actually...
