Hi Folks, I'm a new one to the forum, & have to admit I'm a bit of a fraud. I am just about to embark on my first fiberglassing project & have been searching for info regarding a certain problem I expect to face, in the near future. The only reference I have found to my specific question on the net, is based here on this site. So in short I decided to be a bit cheeky & register in order to gain a little more information if possible.
Not knowing of the world of replica props, looking through your work amazes me. So I figure if anyone should be able to put me on the right track, I guess it would be you lot !.
Now the admission ----- My hobby is boats & I am in the process of building a 9 foot rc control yacht. It is my biggest project in terms of time, size & cost, & it has the added problem that I am using a new material as far as I am concerned, grp. All previous stuff has been timber or steel
The item I came across on the net was " how to fiberglass in tight places, by Nick Daring " & reading on it was suggested that an apple sauce mix is used & then a wet glass tape is used to bond the two halves together. when this is done apply filler to the outside after removing any rubbish.
My question to you is, do you think this process would be ok on a boat hull ?, given the fact that it is going into the water once completed, & is it possible to apply more gell coat to the outside once filled, & then buff & polish afterwards ?.
The reason I have to make my vessel in two halves is because of the tight void down the keel, that I am going to put a cast lead ballast weight in, afterwards.
Many thanks for any help on this subject.
P.S. Although I call myself a fraud, I am also working on a 5' 4" model of the Africa Queen, again a working model once completed, so I suppose thats an RP, although the skill level needed pails in comparison to you lot.
