Tastyburger
Re: First intro; first build! Dr. Doom Pepakura
Bondo is a brand name auto body filler. The reason it's used is to round out the seams and geometry created by the pepakura build.
Be sure to get your alignment straight before you resin/fiberglass it. Use extra strips of paper, or whatever it takes to properly adjust. After a light resin coat on the outside, it should be robust enough to remove the bracing.
The bondo is used because it is more workable than straight resin. That being said; it's somewhat fragile without a solid foundation.
Thanks for the compliment and interest. This was also my first pep build, but I worked very slowly to ensure a decent result. I probably got lucky...
Bottom line: If you can't get your build to where you like it, you may want to consider a rebuild. I'd hate to invest a lot of time into something you'll be fighting with all the way through to make right. Just don't give up on it, and feel free to ask me (a fellow nOOb) or any of the many extremely talented people on this site for help. They are very helpful to those with genuine interest and passion for the hobby.
