EVA Foam help! Covering over and starting fresh
spoonguy80
Hello to all!
I am 90% done with a Hulkbuster Costume made from EVA foam and various materials and I have reached a muddled point with my coating and paint techniques.
Basically I have found that the spray Mod Podge did not quite coat and seal as much as I liked before (4 spray coats) before I moved onto plasti-dipping some parts.
In addition to that, In a sleep addled stupidity I forgot the Plasti-dip and went straight to the primer on some pieces and they cracked.
IS IT POSSIBLE TO COAT EVERYTHING WITH MULITPLE LAYERS OF THE BRUSH ON MOD PODGE AND GET EVERYTHING BACK TO SQUARE ONE LIKE THAT? Or do i need to strip and sand down as much as possible?
CAN I BRUSH ON MOD PODGE OVER SPRAY PRIMER?
any help with this would be appreciated
Thank you
