ozz
Member
So, I was wondering what materials everyone prefers to use to make a buck or to sculpt with to make a buck.
I have tried a few things. I used to work in the molding and casting department for a Dinosaur museum. We used just about everything, and depending on how big the project was for us to make, we used different materials. If the project was big, we used plaster. If it was smaller, we used Bondo, and two part plastic to make the base. We rarely used clay because of the molding and casting process we used. We used the two part foam sometimes as well for really difficult projects that were big and needed a "filler" base.
I am starting to make some casts for Star Wars armor, and helmets. I recently used (just) plaster to carve a full set of clone armor. I decided to do this because of the size, and the plaster stays workable for a few days, as long as it's thick enough, and can be sanded and smoothed out nicely while it is still wet. I am not sure if it will be able to take the vac form process well. I am guessing the heat will destroy the molds/bucks I made in a pull or two.
I even tried to do a plaster base and Bondo on top, but the Bondo keeps the plaster from curing correctly, and makes it a little hard to form (the Bondo) correctly.
Now that I am starting to try to do helmets, I have seen a few ways people have done this foam carving process. I decided on trying the foam back/base carved out into the general shape, and Bondo to cover. I have foam residue everywhere, and it is making the biggest mess. Plaster made a mess, but I just wiped it up with a wet towel, The foam is way worse. lol Like I said: I have rarely used clay for this kind of project.
So, I wanted to know, for the helmet/prop makers out there, what materials/process do you find easiest to make these type of sculpts?
