Would having the base on a rubber pad (or, for elevation, a platform of yoga blocks) help minimize that increased noise?
Maybe I'm being naive here and underestimating just how much work this will entail, but I see patching, sanding, and re-painting.
Possibly not even a full repainting, if the exact color match(es) can be found.
I would definitely like to dial back that checkerboard look, along with some of the too symmetrical weathering. If I can find a close match to the predominant gray, then it would seem to be only a matter of generally misting over to knock some of that back.
Even overspray on decals shouldn't necessarily require replacing them. They are all hard edged lines. Can't they too be edge masked and touched up, if need be?
About the only thing that truly disappoints me in what I'm seeing here, is the saucer support. It makes the base far more predominant in the display than it was before (and it was always significant), which hugely impacts the overall aesthetic for me. And it also forces the side with the plugs to be least obstructed for viewing.
I guess there was no way of getting around it in hindsight, since it's a heavier metal contraption rather than lighter styrene.
Always drawbacks no matter which way you go, it seems.
